Buzzy Vibration at certain RPM's..read before buying!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doobiewah, Oct 25, 2015.
  1. Aug 8, 2016 at 1:02 PM
    #1941
    Tachy
    Tachy Well-Known Member
    Bob
    PA
    2016 Met Grey 4 Door Short Bed Tacoma TRD Sport 3.5
    I'll let you know,, calling soon
  2. Aug 8, 2016 at 1:32 PM
    #1942
    Tachy
    Bob
    PA
    Spoke to a very nice, polite, customer service gent , he took all my information.
    Gave me a new case file number .
    He looked for existing complaints resembling mine, and TSB's , said none existed that he could find for a buzzing vibration problem.
    My reply -- Are you serious ?
    They are referring me back to my dealership's service dept., who is supposed to research their "Techline" for
    similar problems and get back to me in 48 hrs.
  3. Aug 8, 2016 at 2:02 PM
    #1943
    49Tacoma
    49Tacoma Well-Known Member
    2016 Tacoma Limited 4x4
    Yeah, so that response is what they're trained to say when Toyota doesn't have a fix or explanation for the problem. We've all received the same response both from case managers and the initial reps on the phone. Kudos for putting in a complaint and opening up a case number...its our only chance for getting a TSB released. The transmission TSB flash being a good example where enough people complained and Toyota actually did something about it.
    Keep us posted on what your dealer says though. If they're good, they'll acknowledge there's an issue (but will say they have no fix, like mine did).
    smitty99 likes this.
  4. Aug 9, 2016 at 9:08 AM
    #1944
    Doobiewah
    Doobiewah [OP] Well-Known Member
    Robert
    Flagstaff, Arizona
    RIP: 2016 Blazing Blue Pearl Tacoma Limited 4x4
    Now, when I called last OCTOBER, 2015, I could see them saying this as the truck was quite new. For you to have recently called and still gotten the same BS is just disingenuous.
    Many of us have/were assigned to 'Monique' in SoCal. If she calls you, say hi! She'll give you the same line of "no one else has complained of something like this" BS.
    Good luck.
  5. Aug 9, 2016 at 9:18 AM
    #1945
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    sounds about right. no issues reported, it's fine and designed that way.
    They wanted me to do the same and keep running back and forth to the dealer
    for an issue the dealer already said "was normal" I politely told her there was no
    way I'm spending my free time at a dealer who already said "it's normal" and clearly
    wasn't going to spend any more time on the issue just because you want to keep
    wasting my time and sending me back. I have a piece of foam under my mat in the
    only area that has the slight vibe ( the foot rest ) with that there it's hardly noticeable
    so if they find a fix great, if they don't', I've moved on.
  6. Aug 9, 2016 at 9:40 AM
    #1946
    Tachy
    Bob
    PA
    Has anyone tried sending forum links like this to Toyota Corp for a response ?
  7. Aug 9, 2016 at 9:48 AM
    #1947
    Doobiewah
    Robert
    Flagstaff, Arizona
    Yes, I sent them several links. They ignored them. My dealer actually looked at them; however, had nothing to say except that they could do nothing unless Toyota Corporate admitted to the issue and sent a TSB or recall fix.
  8. Aug 9, 2016 at 9:49 AM
    #1948
    BlkTaco47
    BlkTaco47 Unhinged
    Same here, sent to Toyota in my initial complaint, sent and brought to
    dealer and he said the same to me.
  9. Aug 9, 2016 at 1:31 PM
    #1949
    Tachy
    Bob
    PA
    All we can do is share our experience's for now it seems, pool our ammo so to speak.
    Maybe numbers will soon pan out
  10. Aug 9, 2016 at 5:58 PM
    #1950
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I sent the link to my local dealer and they replied they had no reports of vibration issues. I also spoke with the head mechanic at Toyota on Oahu, representing a good chunk of dealers in Hawaii, and same response.
  11. Aug 9, 2016 at 6:58 PM
    #1951
    49Tacoma
    Typical, no reason for them to admit it without Toyota having a TSB to fix it. The tech who rode with me admitted theres excessive vibration off the bat. He thought the motor mounts might be stiff which is causing all the feedback in the cabin and pedal/steering wheel.
    As soon as he mentioned it to the service manager, the service manager took it for a ride on his own (without me there) and said "its normal".
    Ultimately, Toyota leadership and the majority of service managers will continue to disavow any knowledge of it because theres no incentive to fix it. I honestly dont see it ever getting fixed at this point
  12. Aug 9, 2016 at 6:59 PM
    #1952
    49Tacoma
    Also, I had two Toyota customer care reps tell me that they've heard of the issue too. Its really up to who you speak to on the phone. Toyota is well aware of this issue.
  13. Aug 10, 2016 at 1:58 PM
    #1953
    joselo0
    joselo0 New Member
    Jose
    2016 DLCab TRD offRd 2wd
    hi guys, mine (2016 TRD OR 2WD) started doing a vibration once it reaches exactly 79-81 MPH, you can see the front pass seat shaking, it started after the 1st maintenance , took it back and rebalanced the wheels, but still does it, will contact CS to file the report
  14. Aug 10, 2016 at 2:02 PM
    #1954
    COskimtb
    COskimtb Well-Known Member
    25 Sequoia TRD Pro
    The problem in this thread is RPM related not speed related.
  15. Aug 10, 2016 at 9:38 PM
    #1955
    Taco361
    Taco361 Well-Known Member
    Victor
    Corpus Christi, Tx
    2022 TRD Sport 4x2
    Stock "for now"
    Well, truck has been at the dealer for a day and a half now for vibrations issues :mad: haven't heard anything yet. Will update when they don't find the problem.
  16. Aug 11, 2016 at 12:19 AM
    #1956
    BlkTaco47
    BlkTaco47 Unhinged
    Had that on my 2011 too, never figured out what it was. And after reading your post
    I hit 80 mph when I got on 95 last night and cot damn! passenger seat looked like it was
    having a friggin seizure!!
  17. Aug 11, 2016 at 3:26 AM
    #1957
    reg boulette
    reg boulette Well-Known Member
    Start posting about Toyota and its neglect of this problem (and others) on other websites and forums devoted to "truck related" activities - ATVs, fishing, hunting, snowmobiling, etc. so that more people get the message. Anytime you read a "review" of the vehicle by an automotive journalist, use a comment on the story to refer them to this and other threads on this forum detailing all the problems.
    A public shaming? Why not. In the past, Toyota had a reputation for reliability. They currently rest on the myth of this rep. However, it looks as though they have, and are willing to continue, to be no better and in some cases much worse, than the North American auto manufacturers when it comes to denying problems and their obligation to customers.
    deergetr likes this.
  18. Aug 11, 2016 at 4:34 PM
    #1958
    Patrick1046
    Patrick1046 Well-Known Member
    05 AC Long Bed - 16 DC Short Bed - 16 4Runner
    Agreed. I got the call [February 2016] indicating the "Toyota rep," tested similar vehicles with the same results [Normal] the same day the local dealer told me my truck was "not repairable." [Toyota rep. never tested my truck]. Offered refund. Sounded like Toyota corporate was reading from a script.
  19. Aug 11, 2016 at 8:45 PM
    #1959
    Doobiewah
    Robert
    Flagstaff, Arizona
    You should have heard the phone message that 'Monique' left me...a long monotone comment about how Toyota appreciated my letter and comments, blah, blah, blah. It was so 'scripted', and that's the way she read it...didn't even put any life into it.....I certainly was not surprised; however, somewhere out there, 'Monique' was able to click the box to say she contacted me, allowing her to re-close the case.
  20. Aug 12, 2016 at 8:28 AM
    #1960
    Tachy
    Bob
    PA
    I was told I would hear from my dealer within 48 hrs,
    that deadline passed 2 days ago.
    Techline must be experiencing an unexpected surge in usage !
