bvbull200's Gravity Fed Cabinet Smoker Build Thread - Under the Tutelage of Maner
Discussion in 'Food Talk' started by bvbull200, Aug 15, 2019.
  1. Aug 18, 2019 at 3:35 PM
    #121
    Bigdaddy4760
    Maner
    Poolville Texas
    @Misplaced Nebraskan
    Zach still trying to saw that waygu brisket.
    :rofl:
  2. Aug 18, 2019 at 3:42 PM
    #122
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    I survived! so did the brisket!
    Sneak peak here...
    BAPQKSsd3XfREiP4G8yPMpf7WnGt82YAVn6q4MAz_7df241fbfe4681c8c1b9c3e5734cb327605cdbfc.jpg
    Flat on Left, Point on right, and some burnt ends that were melt in your mouth good!
    TRD-ED, Pyrotech, Beretta4x4 and 4 others like this.
  3. Aug 18, 2019 at 3:46 PM
    #123
    Bigdaddy4760
    Maner
    Poolville Texas
    Vacuum seal me a bite.
  4. Aug 18, 2019 at 6:17 PM
    #124
    Pyrotech
    Pyrotech Well-Known Member
    Just A bite?
  5. Aug 18, 2019 at 7:45 PM
    #125
    bvbull200
    bvbull200 [OP] Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    We managed to put a few hours in today.
    Maner sealed up the lower inner skin:
    The inner skin for the left side was also sealed up, then got some insulation. You can see the insulation poking out from the bracing in the middle. We forgot to stuff it before we tacked it on, so we just notched a few spots and loaded it up. That brace was a REALLY good idea. The inner skin had a slight tendency to bulge in the middle. Using that brace as an anchor point for some tack welds, we were able to ensure that the inside skin was nice and flat.
    The outer skin was about to go on, but it was cut to go exactly edge to edge on the frame. The problem there is it makes it hard to tie the outer skin in to the frame. Solution? Offset it on two sides to expose the frame just a tad (it'll get covered with a weld and polished down), the use this big ass grinder to grind the edge back on the two sides where the skin was now 1/8th past the frame. If...nay...WHEN we build another, I think the plan is to get the outer skins cut about 3/16ths shorter on both length and width to make it slightly smaller than the outer size of the frame and, thus, easier to tie in together.
    Did I mention that this was one big ass grinder? :rofl:
    Here is some insulation laid out for the bottom of the smoker. I took the Tetris approach to try and get the most out of that bundle of insulation :laugh:.
    Did a little spitballing with Maner after we decided on a stopping point. We came up with a nifty idea for the door mounted thermometer. More on that when we get to that point.
    We got about 4 hours of work in and made some pretty nice headway. These first three days of building have been really productive and a HELL of a lot of fun. I could spend the day welding, cutting, and grinding with Maner anytime. A cold beer or five along the way doesn't hurt ;). Looking at that thing in the shop, it's pretty amazing how far it's come already.
    I think we're in a holding pattern for the next 3-4 weeks with Maner heading back out in the field. That gives some time for more brainstorming of other ways I can send this build down another tangent :rofl:.
  6. Aug 18, 2019 at 8:02 PM
    #126
    Kanyon71
    Kanyon71 Well-Known Member
    MI
    Coming along nicely.
    Well you did say you where a journeyman grinder so we expect only the best tools. :)
    Bigdaddy4760 and wilcam47 like this.
  7. Aug 18, 2019 at 9:12 PM
    #127
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Looking good. I had a chance to check it out yesterday.
  8. Aug 19, 2019 at 2:47 PM
    #128
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    what color you going to paint it?
  9. Aug 19, 2019 at 2:55 PM
    #129
    Kanyon71
    MI
    Unicorn rainbow I think.
  10. Aug 19, 2019 at 2:56 PM
    #130
    wilcam47
    Will
    Bourbon state
    :rofl:
    Bigdaddy4760 and bvbull200[OP] like this.
  11. Aug 19, 2019 at 2:57 PM
    #131
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    The main color will be the color of the outer ring in our logo. The accent color will be Quicksand (same color as Maner's pit), which is a pretty close match to the tan color in the background of our logo.
    The accent pieces will be:
    The recess for the temp controller
    The shroud for the temp controller
    The shroud for the ball valve/fan
    The main door handle
    The door cover for the chute
    The door cover for the firebox
    The exhaust stack
  12. Aug 19, 2019 at 2:58 PM
    #132
    wilcam47
    Will
    Bourbon state
    That will look great!
  13. Aug 19, 2019 at 2:58 PM
    #133
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    There will be a unicorn snuck in to the design somewhere ;).
  14. Aug 19, 2019 at 3:00 PM
    #134
    Bigdaddy4760
    Maner
    Poolville Texas
    There already is!
    :rofl:
  15. Aug 19, 2019 at 3:01 PM
    #135
    wilcam47
    Will
    Bourbon state
    pics!
    :worthless:
  16. Aug 19, 2019 at 3:04 PM
    #136
    bvbull200
    Bryan
    DFW, Texas
    Fresh wiper fluid
    That's what I get for doing the work in his shop. Having seen his creativity on display, I know that an unsupervised Maner is a dangerous thing. :rofl:
  17. Aug 19, 2019 at 3:05 PM
    #137
    wilcam47
    Will
    Bourbon state
    The rest of us will like it though...;)
  18. Aug 19, 2019 at 3:23 PM
    #138
    Bigdaddy4760
    Maner
    Poolville Texas
    :D
  19. Aug 20, 2019 at 4:39 AM
    #139
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Looking great! I dig the color scheme.
    wilcam47 and bvbull200[OP] like this.
  20. Aug 20, 2019 at 12:31 PM
    #140
    lupard
    lupard Well-Known Member
    Wasilla, Alaska
    That is looking quite nice!
    Bigdaddy4760 likes this.
