Bye bye chrome bumper. hello color matched
Discussion in '2nd Gen. Tacomas (2005-2015)' started by macgyver, Aug 28, 2010.
  1. Aug 28, 2010 at 5:25 PM
    macgyver
    macgyver [OP] Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    So I was browsing advance auto parts today and came across this duplicolor perfect match spray...and what do you know...they have my paint code! Sweet now I have something to do today. I bought two cans of it and some sandpaper, then headed to O'reilly auto parts to buy a quart of clear and some catalyst. I also picked up another can of the silver there since advance only had two.
    Here are some pics so far. I'm waiting on the last base coat to dry then i'm going to spray the clear. The clear will be sprayed with my HVLP gun.
    Enjoy. I will post more pictures when its all done.
    [​IMG][​IMG]
  2. Aug 28, 2010 at 5:31 PM
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    Nice!
  3. Aug 28, 2010 at 5:32 PM
    toojayz
    toojayz Well-Known Member
    Jim
    Northern NJ
    2011 TRD Sport 4x4 DC MGM SB
    Looks great so far, can't wait to see the finished product. Also, I always wanted to try to spray with an hvlp gun. How difficult is this? Thanks!
  4. Aug 28, 2010 at 5:40 PM
    macgyver
    Brad
    Canton, GA
    Its not too hard, you just have to play with the settings on the gun a little to get the right spray fan and amount of paint coming out. I usually just spray a wall or something to get it set right before I spray the piece i'm painting.
    I just sprayed the first coat of clear, about 10-15 minutes flash and then the second coat goes on.
    OBTW forgot to mention the steps I took for those insterested.
    Take all the black trim off,
    then I sanded with 400 grit on a DA sander changing paper fequently.
    Then I wet sanded with 600 grit and a dawn dish soap and water mixture,
    then washed it.
    Then dried it off,
    then wiped down with rubbing alcohol to clean any final residue.
    Then I sprayed with the self etching primer, 3 light coats
    Then 3 coats of base
    Now spraying clear (I recommend wearing coveralls. clear gets sticky especially for hairy guys like me)
    Follow all directions for proper dry/flash time.
  5. Aug 28, 2010 at 5:43 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Wish I had an hvlp gun.... Painting is fun, but prepping sucks :(
  6. Aug 28, 2010 at 5:43 PM
    toojayz
    Jim
    Northern NJ
    Wow, thanks so much for the info! :)
  7. Aug 28, 2010 at 5:43 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    very nice job
  8. Aug 28, 2010 at 5:44 PM
    ImpulseRed008
    Susan
    SC
    Oh, yeah.... looks good. :eek:
  9. Aug 28, 2010 at 5:52 PM
    toojayz
    Jim
    Northern NJ
    1 more question, can that clear be sprayed without "reducing"? There are alot of chemicals and can be a bit confusing at times. It would suck to buy the paint/clear and screw up the mix before you even spray or worse, ruin your prep work and have to start all over again! :(
  10. Aug 28, 2010 at 5:53 PM
    pinktaco808
    pinktaco808 Hot Steppa
  11. Aug 28, 2010 at 5:58 PM
    macgyver
    Brad
    Canton, GA
    You dont have to reduce clear, you mix a catalyst in it which activates the clear and causes it to harden. Sometimes I will mix a tiny amount of reducer in the clear to let it lay flatter but the clear seems to be laying pretty flat today (perfect temp and low humidity today)
  12. Aug 28, 2010 at 5:59 PM
    Freelance
    Freelance Well-Known Member
    Curtis
    Las Vegas, NV
    07 DC PreRunner SR5
    Sweet! Looks good so far man.
    Would love to do the same with mine, but the Duplicolor "Color Match" for Toyota's Super White didn't match up for me when I tried my grille surround. Came out yellow at first. Then even after a second attempt the white was perfect, but still didn't match up perfectly and bugged the crap out of me. So I blasted it black and ordered a white grille from the dealer.
    But would LOVE to get rid of that last bit of chrome! Thought about trading for a black bumper, but color matched would be ideal! Interested in how the final product turns out, and I give you props for the work. Just my grille surround was a bitch!
  13. Aug 28, 2010 at 6:00 PM
    macgyver
    Brad
    Canton, GA
    Ok I just finished the clear coat. Here are pics. I'm gonna let it dry overnight and put it back on tomorrow morning.
    You can see my trusty harbor freight HVLP spray gun. I have painted many cars and many pieces of furniture with that thing. Cost me $65 about 4 years ago.
  14. Aug 28, 2010 at 6:01 PM
    toojayz
    Jim
    Northern NJ
    Cool, thanks again!
  15. Aug 28, 2010 at 6:07 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Hopefully it matches well! I tried that for my truck and it was close but you'd definitely notice the difference against the truck. I've got a superwhite though and I'm finding that white is a tough color to match!
    Looks great so far!
  16. Aug 28, 2010 at 6:16 PM
    macgyver
    Brad
    Canton, GA
    Its hard to get a perfect match with paint unless you paint everything at the same time. Fortunately for the bumper, the black trim is there to "break up" the difference.
  17. Aug 28, 2010 at 6:31 PM
    NitroCircus177
    NitroCircus177 Well-Known Member
    Scottsdale, AZ
    05 Black PreRunner BHL
    try automotivetouchup.com for the paint. I used them for when I painted my grille surround. Although I have BSP it is pretty much identical to the original paint on the rest of the truck. I used the aerosol can but they have paint for a spray gun which will probably give you a much better result.
    Ill have to look back to another forum topic but im pretty someone us automotive touch up on a super white bumper and it turned out really good.
  18. Aug 28, 2010 at 6:33 PM
    BlancoTaco08
    BlancoTaco08 Well-Known Member
    Looking forward to the finished product!
    Sub'd
  19. Aug 28, 2010 at 6:40 PM
    JAG
    JAG Well-Known Member
    So when can I bring my truck up to you? haha :D
  20. Aug 28, 2010 at 6:51 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    awsome! this is def my next project. i HATE my chrome bumper :mad:
