Bypass dimming temp. compass, clock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zeus, Mar 11, 2011.
  1. Mar 11, 2011 at 4:49 PM
    zeus
    zeus [OP] Member
    Is there any way to bypass the temp, compass , clock dimming feature when the headlights lights are left on for daytime driving .
  2. Mar 11, 2011 at 8:06 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    For a 2010 (yours may or may not be the same):
    For the clock, it's the green wire on pin 11 (center bottom) of the plug.
    For the temp/compass, it's the green wire on pin 4 (top, next to the end) of the plug.
    "Top" is the side of the plug with the latch on it.
    Those green wires have 12 Volts on them when the headlights are on. You may be able to just cut them to get full brightness, or you may have to cut them AND ground the clock and the temp/compass green wires to get them to be bright.
  3. Mar 12, 2011 at 6:23 AM
    zeus
    zeus [OP] Member
    where are the plugs located.
