Bypass Parking Brake for DVD Head Unit
Discussion in 'Audio & Video' started by Toddjt, Mar 27, 2012.
  1. Mar 27, 2012 at 4:55 PM
    Toddjt
    Toddjt [OP] Well-Known Member
    Todd
    Greenville, SC
    Red 05 Dblcab V6 Manual SR5
    bull bar and warn winch 2.5" spacer lift wheels and tires
    Hey guys.. just installed my new kenwood ddx319 into my 05 tacoma double cab non-JBL system.
    I have searched this topic and haven't found a thing yet.. so my question is:
    How can I bypass the parking brake to be able to watch videos from my iPod and DVDs while the parking brake is not on? I went ahead and put the unit in, and I know I will have to take it back out to run this parking brake wire. I had no idea what to do with this wire, so I left it out completely since I don't really have anything to watch right now anyways, and I already knew I wanted to bypass it.
    Everything else with this unit is working flawlessly. The instructions from crutch field were, for the most part, easily understandable.
    The install was fairly clean, besides that annoying clock/hazard piece. Here are some pics of the new unit and the wire that isn't currently hooked up (E-Brake wire)
  2. Mar 27, 2012 at 4:56 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Just ground it
  3. Mar 27, 2012 at 5:03 PM
    Toddjt
    Todd
    Greenville, SC
    I thought about doing this.. I said "there's no way it can be that simple..." lol!!
    Thanks
  4. Mar 27, 2012 at 5:10 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
  5. Mar 27, 2012 at 5:12 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    Buy a switch for like 2 bucks, cut the parking break. Hook up positive from the parking break to positive on the switch and same with negative. Stick the switch somewhere and your done. Did it in a couple minutes
  6. Mar 27, 2012 at 5:15 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    I tried grounding mine but didnt work. Maybe I had a bad ground though. Worth a shot either way
  7. Mar 27, 2012 at 5:23 PM
    08bluetacoma
    08bluetacoma Well-Known Member
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    6 inch fabtech alpine stereo flowmaster exhaust
    yah my buddy has a ken wood double din and he just grounded the wire. clarion and pioneer are a pain
  8. Mar 27, 2012 at 5:25 PM
    Aw9d
    Aw9d That one guy
    A lot of decks this doesn't work.
    look up how to bypass parking break with relay. 8$ at autozone and your good to go.
  9. Mar 27, 2012 at 5:40 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    i used a 12v relay, but i have a pioneer
  10. Mar 28, 2012 at 7:06 AM
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    Hit up youtube or try google. MFG's change how they do it on occasion, but in general, the relay will work for most units, as it is a delayed ground connection, simulating starting the vehicle and putting the parking break on (what is required by most).
    Pioneer is usually quite simple, in many units its just moving a wire in the harness.
    If not this, then the relay.
    Alpine units are generally done with a PAC adapter, the TR7 IIRC.
  11. Mar 29, 2012 at 12:22 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    I had a Kenwood DNX 8120 in my FJ. Ground that beotch... It works. Just don't have a movie playing if there's a trooper chattin' you up!!
  12. Apr 1, 2012 at 6:56 PM
    Toddjt
    Todd
    Greenville, SC
    I went ahead and bought a switch to use so that I could cut the movie off fast in the event that a cop were to pull me without warning.
    Here is the switch and the directions for it.. I haven't had a chance to install the wire yet but my best guess is to cut the parking brake wire in two, put one of the new wires from the top prong on the switch to the ground, and put the other new wire from the back of the head unit to the bottom prong on the switch. Is this the right idea?
    Just want to make sure before I pull it all back out because I have never used a switch before in my wiring experience.
  13. Apr 2, 2012 at 2:41 AM
    CantSitStill
    FTR
    CNY
    The switch is now your "parking brake". When the switch is closed, or on, your head unit is grounded and thinks the parking brake is on and lets you play a movie. You won't need to touch the actual parking brake wire.
    Ground to switch, switch to head unit.
  14. Apr 2, 2012 at 3:00 AM
    broth9488
    broth9488 Member
    Bryan Roth
    Norfolk Virginia
    2011 Prerunner Sport
    18x9 XD monsters, 285/65/18 Nitto Grapplers. 3in suspension lift.
    I got the same head unit in my truck and love it. Did you have the steering wheel control adapter put in too? The only problem ive found with that is the stereo will randomly switch songs or modes. Im pretty sure its not the head unit and is just a poorly programmed adapter.
  15. Apr 2, 2012 at 3:27 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Dumb question, but can't you just click the parking brake one click? Thats how my old car turned off the drtl's, so shouldn't it be th same for those radios?
  16. Apr 2, 2012 at 5:56 PM
    positraction127
    positraction127 Active Member
    MN
    2011 TRD Sport DCLB 4X4
    I put a DDX419 with the Axxess steering wheel adapter in my Taco and it's doing the exact same thing. This must be a known problem so maybe I'll call Crutchfield.
  17. Apr 2, 2012 at 5:57 PM
    positraction127
    MN
    Just hook up that reverse wire to ground on the Kenwood radios. I soldered it into same ground for the head unit and steering wheel adapter. Works perfect.
  18. Apr 3, 2012 at 5:59 PM
    Toddjt
    Todd
    Greenville, SC
    Does anything need to go on the middle prong of the switch though?
  19. Apr 4, 2012 at 4:37 AM
    CantSitStill
    FTR
    CNY
    Took a look at your instruction picture. Is this a lighted switch? From your intructions, I would say you want to go bottom pin (they say 12v+) to the ground, and middle pin to the parking brake lead of your stereo. This switch is interrupting the middle and bottom pin. The top pin that they want you to ground I assume is due to a lighted switch.
  20. Apr 5, 2012 at 12:34 PM
    Toddjt
    Todd
    Greenville, SC
    This is a lighted switch, but I couldn't care less if it lights up or not. I just want it to serve the purpose of allowing me to view video media when flipped on, and preventing me from viewing video media when flipped off.
