Bypass Passenger Airbag Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by morgul.03, Jun 12, 2017.
  1. Jun 12, 2017 at 9:33 PM
    morgul.03
    morgul.03 [OP] Well-Known Member
    08' SSM AC TRD OR
    How do I remove the passenger airbag switch? I know the harness is unused on double cabs and newer access cabs.
  2. Jun 14, 2017 at 6:14 PM
    morgul.03
    08' SSM AC TRD OR
    Anyone?
  3. Jun 14, 2017 at 6:14 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    What are you trying to accomplish ? did you swap seats ?
  4. Jun 14, 2017 at 6:19 PM
    morgul.03
    08' SSM AC TRD OR
    No, my passenger seat is the same. I swapped the exterior of the radio to the 2012 - 2015 one that doesn't have a spot for the switch.
  5. Jun 14, 2017 at 6:23 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    If tour truck came with it you mist keep it. You have to leave it connected and " on " just stash it behind the dash if you don't want to see it. If you disconnect it your airbag system light will come on and the entire system will not fire if it is in an error mode. When an error exists it kills the whole damn deal.
  6. Jun 14, 2017 at 6:27 PM
    morgul.03
    08' SSM AC TRD OR
    I already figured that part out haha. It says airbag off and I have the warning light. Guess I'll just have to swap it switch back on and leave it behind the dash. How do the double cabs work without that switch?
  7. Jun 14, 2017 at 6:46 PM
    EPBlueTaco
    EPBlueTaco Well-Known Member
    Ted
    El Paso
    07 DCLB SR5
    None yet
    My 07 double cab has a sensor in the passenger seat and it turns on if some one is sitting in it. No bypass at all
  8. Jun 14, 2017 at 7:16 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    some double cabs had it too, it is just different versions of the whole system over the years.
  9. Jun 14, 2017 at 7:57 PM
    Muddinfun
    Muddinfun Well-Known Member
    Meter the switch and see what it does. If it just connects 2 wires, just solder and heatshrink the wires. Although probably not "Kosher" for airbag stuff, probably neither is hanging the switch behind the dash.
    morgul.03[OP] likes this.
  10. Jun 14, 2017 at 10:14 PM
    morgul.03
    08' SSM AC TRD OR
    That's kind of what I was thinking. I'm guessing with the switch removed then the passenger airbag is open AKA off, if I close the switch it will go back to auto mode. Honestly, hanging the switch behind the trim is sounding like a better option more and more
  11. Jun 14, 2017 at 10:59 PM
    Muddinfun
    Just had an idea. Can you mount the switch so that it's accessable when you open the glovebox?
  12. Jun 15, 2017 at 4:16 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    My airbag off is always lit up but its over there and I'm over here not looking at it so it dont bother me.
  13. Jun 15, 2017 at 6:15 AM
    morgul.03
    08' SSM AC TRD OR
    I'll have to see if I have enough cable to route it to the glovebox, that's not a bad idea.
  14. Jun 15, 2017 at 6:17 AM
    Muddinfun
    "Does this thing have airbags?"
    "Your side does. I don't know about mine"
  15. Jun 15, 2017 at 5:59 PM
    morgul.03
    08' SSM AC TRD OR
    Haha, don't have to pay to replace airbags if they never blow!
