Bypass pipe, now a vacuum leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by papergirl, Jan 4, 2023.
  1. Jan 4, 2023 at 2:17 AM
    papergirl
    papergirl [OP] Member
    Patti
    2006 Tacoma 2.7
    Good morning!
    New to the forum, thanks for having me. My 06tacoma 2.7 with 180k miles is due (over) for a lot of repairs and maintenance, and I am learning as I go.
    What I have crossed off the list so far:
    All four struts/ coil
    Front brakes
    Reverse switch (that was leaking but I snugged it down and is ok now)
    Water bypass pipe
    still to go, may wait till spring:
    -Oil pan is rusted at the seam, not leaking yet but I’d like to replace next oil change
    -complete fluid change trans, front+rear diff, I looked up the oil and that’s going to be pricey
    And now I am thinking I should have replaced the intake manifold gasket, throttlebody gasket, and a few of the vacuum lines while I was in there doing the water pipe. This was an intimidating project for me, and money is tight and the gasket looked ok so I left it.
    After reconnecting everything the truck runs fine, I just took it down for inspection. But the first 10 to 15 seconds after starting up there’s a hissing sound followed by kind of a quick poof and then the truck operates normally.
    Are there any other symptoms that would indicate a vacuum leak, any advice on pinpointing the source or should I remove the intake again and do the gaskets?
    Thanks
    ToyoTaco25, Torspd and HondaGM like this.
  2. Jan 4, 2023 at 3:30 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Welcome to TW, Patti!
    HondaGM and papergirl[OP] like this.
  3. Jan 4, 2023 at 6:58 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Welcome!
    If It were me I would take it down again and replace all the gaskets involved. You should always replace the gaskets and seals when you reassemble. It prevents doing the job twice.
    JGO, HondaGM, TnShooter and 1 other person like this.
  4. Jan 4, 2023 at 7:49 AM
    papergirl
    Patti
    2006 Tacoma 2.7
    Yes that is what I will do. At least this time will be easy cause I have already done it, and broken through all the dam the rust.
    I tried capturing the hiss poof/whistle pop sound when I started the truck this morning but it didn’t do it.
  5. Jan 4, 2023 at 12:18 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It should be a snap as you already have a practice run completed.
    Wishing you the very best!
  6. Jan 11, 2023 at 6:53 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    There is a small vacuum hose on the back of the intake by the firewall, passenger side.
    It's really hard to see and easy to miss when putting it all back together after removing the intake.
    Check for that before you take it all back apart, could be an easy fix.
    And welcome to Tacoma world!
    HondaGM and Steves104x4 like this.
  7. Jan 11, 2023 at 6:58 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW Pat
  8. Jan 12, 2023 at 3:31 AM
    papergirl
    Patti
    2006 Tacoma 2.7
    When I double checked all the hose connections, I did make sure to look at that one. that’s actually the hose whose clamp was rusted and broken and needed to be replaced, also the end of the hose was a tiny bit dry rat, but not beyond the clamp. Is it possible that i reattached one of the hoses not on all the way, and the vacuum pressure when I ran the truck snugged the hose on for me? The sound has not returned, I only heard it twice right after reassembly. Now everything sounds and runs great.
    Winter came back here, so I’m waiting for a sunny day to do any more non-emergency projects :)
    And thank you for all the welcomes and advice!
    Steves104x4 likes this.
  9. Jan 12, 2023 at 3:41 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Dry rotted hoses need to be replaced
  10. Jan 12, 2023 at 5:05 AM
    papergirl
    Patti
    2006 Tacoma 2.7
    Will do, in spring. Along with new gaskets and a thorough cleaning, that leaking coolant did a number. I don’t have a garage, so if it doesn’t leak and drives good then I’d better wait for good weather.
    Jimmyh likes this.
  11. Jan 12, 2023 at 10:33 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Hiss and then poof might be the air injection pump cycling on, normal on cold startup
    Do you have a little scan tool that can read codes and data? Long term fuel trims would quickly tell if you have an intake leak
  12. Jan 14, 2023 at 2:00 AM
    papergirl
    Patti
    2006 Tacoma 2.7
    “Do you have a little scan tool that can read codes and data? Long term fuel trims would quickly tell if you have an intake leak”
    I don’t have a scanner, is it the same code reading tool they use at the auto parts store to diagnose check engine light? And would having the battery disconnected reset/ clear out the old information?
  13. Jan 14, 2023 at 5:04 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Mine snapped off from being old. I jb welded it a few years ago. It's still holding up. Problem solved
  14. Feb 13, 2023 at 11:13 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "Oil pan is rusted at the seam" You might want to clean it really good and use some JB
    Weld - It's worth a try - It's expensive to replace the oil pan - JB Weld is next to nothing in comparison.
    JGO likes this.
  15. Feb 13, 2023 at 11:42 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    Years ago, I did the JB Weld to my then girl friend's Chevy Vega. It held for a long time, at least to junk yard.
  16. Feb 13, 2023 at 3:33 PM
    george3
    New Jersey
    Curious - What's a long time ?
    JGO[QUOTED] likes this.
  17. Feb 13, 2023 at 10:17 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I bought a purple ‘75 Astre from the original elderly lady. Perfect purple interior. On my way home I opened the ashtray and it was perfectly clean with the original dealer key tag. It was the most fun car until the tree fell on it. Edit: shit and I paid $185 for it and drove it for 3 or 4 years
  18. Feb 14, 2023 at 5:17 AM
    JGO
    Over two years and then I lost contact with her and the Vega. I was not disturbed by the loss of either.
    Jimmyh likes this.
  19. Feb 14, 2023 at 8:55 AM
    george3
    New Jersey
    Sounds like it's worth a try .
  20. Feb 14, 2023 at 1:19 PM
    Black Bean Taco
    Black Bean Taco Well-Known Member
    2012 Tacoma Regular Cab
    265s, tint, head unit, sub, toolbox, LED light bar
    T
    Thats what I was gonna say. Mines always been loud on cold start then poof and quiets down
