Bypassing Iphone poor sound quality
Discussion in 'Audio & Video' started by winterboy04, Oct 5, 2011.
  1. Oct 12, 2011 at 8:51 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Yeah, there's plug ins and apps for stuff like that but sometimes it's more of a pain than it's worth. That's why I stick to WAV. As long as you backup your Windows Media Player database or the iTunes database it's a non issue.
  2. Nov 10, 2011 at 4:31 AM
    winterboy04
    winterboy04 [OP] Professional Cube-Jockey
    MA
    07 SR5 TRD (Bright Red)
    Alpine CDA-9886 Hybrid Audio Unity Series components JL 250.1, JL300.4 Infinity Perfect 10.1 SVC 4ohm in custom enclosure / amp rack Alpine PXA-H100 Processor FatMat everywhere URD short shifter OEM Bed Mat Tail Gate Safety Mod (Plumbing clamps) Pro-Dry S Filter
    Well, after going through the "Apple Lossless" conversion of a good portion of my songs, i can honestly say that its EASY to tell a significant difference in the sound quality. The lossless versions (while still probably not as good a a .WAV file) are so much crisper and "fuller". Thanks for the help.
  3. Nov 10, 2011 at 9:49 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    Give it another couple months, and then subscribe to Apple's Itunes Match.... auto upgrade to 256 kbps AAC
  4. Nov 13, 2011 at 3:06 PM
    Madjik_Man
    Colorado Front Range
    Apple Lossless is all I try to import.
    However a 320 kbps mp3 sounds very good as well
  5. Nov 13, 2011 at 3:07 PM
    Madjik_Man
    Apple Lossless is just that... lossless. Much like a .wav file. However the Apple Lossless compression is much more efficient (read: smaller file) than a .wav file
  6. Nov 14, 2011 at 7:39 AM
    winterboy04
    MA
    I'm not suite sure i follow...they are going to offer an Auto upgrade of your current files?
  7. Nov 14, 2011 at 9:58 AM
    Madjik_Man
    I'm not exactly sure what that means either.
    If you have a 128 kbps mp3 file and "upgrade" it to a 256 kbps AAC, it won't sound any better... it'll just take up more drive space.
    You can't add back lost signal to a lossy file.
  8. Nov 15, 2011 at 11:04 AM
    winterboy04
    MA
    i know that when you "convert" from regular apple files to the lossless, it actually screates a second copy of the song in a much higher bitrate. For instance, i made a lossless copy of a 128kbs Counting Crows Song (that i downloaded from itunes) and the copy "said" it was 900kbs (900-something, i don't remember the exact number). When played one after the other, there was SIGNIFICANT difference. I'm not 100% sure, but i THINK iTunes re-downloads into the higher bit rate if you own the song. i have not yet tried it on a song i didn't download from iTunes though.
    As a side note, the converted files i have been making do, in fact, take up significantly more space on my iPhone....so i can only imagine the are new bitrate versions of the same songs.
  9. Nov 15, 2011 at 1:38 PM
    81shark
    81shark Well-Known Member
    say what....neither will sound great on a good system, but 256 will sound better than the 128
  10. Nov 15, 2011 at 1:39 PM
    81shark
    that's why i went with the 250 gig ipod classic....for music storage.
  11. Nov 15, 2011 at 5:58 PM
    Madjik_Man
    If you convert a 128 kbps mp3 to a 256 kbps mp3, they will sound exactly the same. Only the 256 kbps mp3 will be larger in size.
    Once you compress a file into a lossy format such as an mp3, there's no "getting back" the signal you lost.
    Now if you go back and import that original file as a 256 kbps mp3 then yes, it will sound better than what the 128 kbps mp3 sounded like.
  12. Nov 16, 2011 at 1:44 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    I have noticed the same problem in my truck since I upgraded the stereo. I have been downloading 320kbps MP3, but they still sound compressed on the new system. I have an Alpine CDA-117 head unit and am wondering if there is any way to play FLAC on it? Can putting Rockbox or similar on my Ipod classic 160 gig give that flexibility, or am I stuck with WAV's?
  13. Nov 16, 2011 at 7:47 AM
    81shark
    I could be wrong, but i thought we were talking the itunes match thing a ma jig. where they replace your 128 file with a 256 file.
  14. Nov 16, 2011 at 7:49 AM
    81shark
    i read someplace once that you could modify an ipod to play flac files, although i never tried to do it.
    i have always just coverted my flac files
  15. Nov 24, 2011 at 8:31 AM
    #35
    Madjik_Man
    If you are using an iPod convert the wav files to apple lossless files.
    Same exact sound quality in a smaller sized file. It'll save you a lot of disk space in the long run
  16. Nov 24, 2011 at 8:34 AM
    #36
    Madjik_Man
    I was talking about the match thing a ma jig too.
    If they can somehow read your library and truly replace your file with a higher bitrate file, then of course it'll sound better. I just thought that's impossible for Apple to do with copyright laws and all.
    I was under the impression that if they just "up converted" your 128 kbps mp3 to 256 kbps, then you will gain absolutely nothing in terms of sound quality.
