Bypassing Pioneer AVIC-X920BT?
Discussion in 'Audio & Video' started by memario1214, Aug 23, 2010.
  1. Aug 23, 2010 at 8:07 PM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I recently purchased the Pioneer AVIC-X920BT out of the Amazon deal and I got it all installed. The only thingis that I can't for the life of me figure out how to bypass the security settings. I have tried grounding the park brake wire like I did in the past, but this time is a no go. It is a pain having to stop to input new coordinates into the navi unit. Anyone have any help for me?
  2. Aug 24, 2010 at 3:22 AM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
  3. Aug 24, 2010 at 4:16 PM
    rocket_scientist
    rocket_scientist Well-Known Member
    Northern VA
    I did the mod to the wiring harness on mine like the link says. Works fine, no problems. Just disconnect the parking brake wire from the brake circuit before you ground it.
  4. Aug 24, 2010 at 5:57 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Was it hard to get the pin out and move it over? I read through that link and a lot of people seemed to break the pin.
  5. Aug 25, 2010 at 4:34 AM
    rob_s
    rob_s Well-Known Member
    SE FL
    White 2010 DC SB Sport
    Glad to see this thread as I just purchased one and want to perform the same override.
  6. Aug 25, 2010 at 3:35 PM
    rocket_scientist
    Northern VA
    It wasn't hard to do. Just follow the instructions on the video from that link. Just go slow. Use a good razor blade to make the cuts and don't try and force it out. If it doesn't pull out easy, just use the razor blade to widen the cut. Also, open the lock on the pins to remove tension when inserting the pin into the next opening.
  7. Aug 25, 2010 at 3:42 PM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Its not difficult at all.
    I did it for my x910, and it was easy, just don't force it.
    Here is the video I used, and it was helpful, showing how to switch the wires out of the pin configuration.
    http://www.youtube.com/watch?v=8HL5pkAKkkA
