Bypassing the A/C compressor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calmwaters3030, Jun 27, 2014.
  1. Jun 28, 2014 at 9:19 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Use a small pipe as a stethoscope.
    Run the engine, have someone hold the throttle high enough above idle so the noise is apparent, then put the pipe to your ear and move it around the engine compartment listening for the source.
    AC clutch failures are not that common. Idler and water pumps are. I replaced my water pump a month or two ago.
  2. Sep 17, 2014 at 6:22 AM
    cjg
    cjg Member
    North Waterboro Maine
    I'm having the same issue, AC pump is shot. Anyone figure out for sure if this can be bypassed?
  3. Aug 4, 2018 at 3:20 PM
    Jon G
    Jon G Hoarding Tacomas one at a time,
    Jon
    St John's Newfoundland Canada
    02, 04 & 07 Tacoma
    Magnaflow 2.5 Catback Exhaust K&N filter
    Same boat anyone figure this out ?
  4. Aug 6, 2018 at 7:30 AM
    Jon G
    Jon
    02, 04 & 07 Tacoma
    My Compressor does not spin at ALL burned the belt off of it :(
  5. Aug 6, 2018 at 7:31 AM
    Jon G
    Jon
    02, 04 & 07 Tacoma
    Bad news i need to either find a AC compressor delete kit to replace the stuck one i have or take the one i have apart and try and free it up and probably put new bearings in it just act as a dead pulley.
    There has been lots of talk about delete kits but i can not seam to find one to fit, also people are saying you will lose your defrost if you delete it. I do not think this is true because you still have a heater core the defrost will not be conditioned air
    I need defrost but i do not need AC defrost
    It will cost more then the truck is worth to put working ac back on it, AC pump, hose, cleaning, pressurize test, fill.
  6. Aug 6, 2018 at 9:07 AM
    Jon G
    Jon
    02, 04 & 07 Tacoma
  7. Aug 6, 2018 at 9:08 AM
    Jon G
    Jon
    02, 04 & 07 Tacoma
    [​IMG] The link above has a listing for a FJ that has the 4.0L wonder if this would work
    knottyrope likes this.
  8. Aug 6, 2018 at 9:32 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Years listed for the 4 runner and FJ are the single vvti motor so it should work.
    Jon G[QUOTED] likes this.
  9. Aug 6, 2018 at 9:33 AM
    Jon G
    Jon
    02, 04 & 07 Tacoma
    thats what i am thinking
  10. Aug 23, 2018 at 6:47 AM
    Jon G
    Jon
    02, 04 & 07 Tacoma
