Bypassing the Reisistors on LED Turn Signaling Bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BLKTRDPRO, Feb 23, 2019.
  1. Feb 23, 2019 at 12:17 PM
    BLKTRDPRO
    BLKTRDPRO [OP] Well-Known Member
    2019 Black Tacoma TRD Pro
    Hello,
    I want to change my front turn signal bulbs to LED, I heard that I am required to have a reisistor. Is there anyway that I can bypass the need of having a resistor? Thanks.
  2. Feb 23, 2019 at 12:21 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    No. Without the resistors you will get hyper-flashing. They are not difficult to install
    BLKTRDPRO[OP] likes this.
  3. Feb 23, 2019 at 12:24 PM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
  4. Feb 23, 2019 at 12:29 PM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    I also just picked up the same ones. No issues. 10 second install.
    Brighter and gets rid of the orange/amber in the headlight.
    I've been reading a lot about the LED turn signals. It seems a lot of the fronts will be fine without resistors. Once you install LED's in the rear, hyperflashing will occur. Something with the load/draw disbursement. @BLKTRDPRO - Read here: https://www.tacomaworld.com/threads/led-lighting-conversion.436865/page-205
    Start at 205 and go backwards. A lot of updates since then. Don't even bother reading in the beginning. Only thing I've seen is that some of the cheaper options will work fine for the fronts because of the way the Tacoma's are wired.
    I was eyeballing this: https://www.amazon.com/dp/B07L6S5NBR
    Resistor is build into the small housing and you have plenty of room between the body and rear tail light. I like this because it's easy and priced well.
    @mesojdm also has a plug n play kit. The benefit of this is utilizing the entire taillight for better output/visibility. Does cost more $$$. I believe $110 - $240 depending on which kit. Also features the switchback.
    Others also make adapters for the lights where they are plug and play. No splicing or soldering.
    Rear turns are 7443 and Front turns are 7440. There are ways around splicing/soldering. Just do your research. Sometimes it's better to buy your own adapter/connectors and make your own harness. Seems like a lot of them come apart over time. Can always buy a harness and just make it better. Get shrink wrap and solder the connections. You can usually find a set for $8-$20. Just find a good mounting point.
  5. Feb 23, 2019 at 1:01 PM
    COSTCOHOTDOG
    COSTCOHOTDOG Well-Known Member
    2018 TRD OR DCSB 6MT
  6. Feb 23, 2019 at 1:24 PM
    slowlane
    AZ
    16 double cab MGM
  7. Feb 23, 2019 at 2:14 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    There is a lot of talk about hyper-flashing, which may, or may not happen if you're only replacing the fronts, but there is something else to watch out for if you start swapping in more LEDs; a single flash, or no flashing at all.
    After replacing incandescent bulbs with LEDs, check for proper functionality with the engine off, AND with the engine running. The system might flash properly with the engine off, but may flash once, or not at all, with the engine running. Properly sized resistors will eliminate this issue. If you have LEDs all around, a 10 ohm resistor in each taillight circuit seems to be the sweet spot.
  8. Feb 23, 2019 at 2:38 PM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    I've also found having the headlights on versus off can produce different hyperflash results. Test it both ways.
    I ended up with 15-ohm resistors wired into the rear turn signals (also converted to LED) but didn't need resistors in the front after putting in the LED bulb.
  9. Feb 25, 2019 at 6:05 AM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    So the XSpeeds look good for the fronts. What about the rears. They are clear. Or you could you use Red. What is everyone using for rear LEDs.
  10. Jun 4, 2019 at 10:16 PM
    Knapz
    Knapz Well-Known Member
    El Paso, TX
    2019 DCSB TRDOR / Dual-motor CyberTruck pre-order
    FOX 2.5/2.0 resi & DSC, OVTUNED, Archive Garage hangers,
  11. Jun 5, 2019 at 9:11 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    Hyperflash happens when the total power load of the turn signal circuit drops below some critical level. The system interprets that as a bulb out and hyperflashes to indicate that a bulb failed.
    Since modifying the flasher circuit itself isn't feasible, avoiding hyperflash when converting to LEDs is a game of keeping the load of the flasher circuit high enough not to hyperflash and low enough not to overload the circuit.
    In my iterations of bulb combinations, I found that you can get different results with different bulb combinations, as well as different electrical system statuses on the truck (ignition on/off, lights on/off, etc.).
    If you aren't doing anything really fancy (aka: Meso mods), you can replace all your standard signal bulbs with LED and know that you'll need a load resistor per side for the turn signals. 6-ohm will work, but you can get away with 10-ohm or maybe higher. You do NOT need a resistor per bulb. You need one per CIRCUIT. It can be installed in the front or back and makes no difference electrically.
    DirtyDan likes this.
  12. Jun 5, 2019 at 3:12 PM
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    Why not?
  13. Jun 6, 2019 at 5:20 AM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
    The flasher is built into the instrument cluster. It isn't a standalone relay.
  14. Jun 6, 2019 at 6:42 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    As resistance drops the current through the circuit increases, the increased current causes the pulse of the blink to increase in speed. Basically the lower resistance of the LED circuit results in more power through the bulb. This is why some people have blown fuses or have other issues when installing LEDs in modern vehicles. If you had a voltmeter with the resistance function you could measure the OEM bulb from lead to lead and compare against the LED you have to put it. The difference would tell you what type of resistor you would need.
    *edit* The reason for hyper flash from a blown bulb is similar, the loss of resistance in the bulb circuit results in another bulb receiving more current.
  15. Jun 6, 2019 at 7:19 AM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
    It's not a matter of resistance in the circuit. LEDs aren't a resistive load. The circuit is only concerned with current. To determine the size of the resistor, you need to figure out what size resistor will mimic the load of the bulb you're replacing.
    EXAMPLE: If you're replacing a 15w bulb with a 1w LED, you need to find a resistor to dissipate 14w to make up the difference. In practice, that value can be more or less and still fall within the tolerances of the circuit. Ohm's law will get you the exact value.
    Power (P) = Current (I) x Voltage (V): 14w = I x 14.4v = .97 amps
    Voltage (V) = Current (I) x Resistance (R): 14.4v = .97A x R = 14.8 ohms
    Xx_Evilvirus_xX likes this.
  16. Jun 6, 2019 at 8:15 AM
    Xx_Evilvirus_xX
    Houston, TX
    That would explain why I couldn't find it when I was installing my dashcam. Thanks
  17. Apr 12, 2021 at 6:48 PM
    tag610
    tag610 New Member
    2018 MGM TRD Sport
    I’m new here, and I know this may be a long shot because it’s an old post.
    I just replaced all turn signals with LEDs and installed 50W 6ohm resistors on the rear turn signals. I realized the video I watched listed the wires to splice incorrectly, as I was getting hyperflash intermittently. So I un-spliced the incorrect wires and spliced the correct ones.
    Now, the turn signals flash fine with headlights on, but only flash once when headlights are off or DRLs are on. Could the size resistor used be my issue? Should I go up to a 10ohm resistor?
    Thanks in advance!
