C. B. help installing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BatesY, Dec 8, 2008.
  1. Dec 8, 2008 at 12:36 PM
    BatesY
    BatesY [OP] Well-Known Member
    ashland oregon
    07 tacoma 4X4 trd sport 6spd V6 sr5
    33" tires 1" block in rear revteck leveling kit front and a sented dolfin from my girl friend :)
    where have anyone who has one put it?
    pics please :)
    thanks
  2. Dec 8, 2008 at 12:37 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
  3. Dec 8, 2008 at 1:00 PM
    BatesY
    ashland oregon
    when you hit the brakes does that fire stick hit your cab?
  4. Dec 8, 2008 at 1:05 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    not my truck but i dout it they are stiff
  5. Dec 8, 2008 at 1:08 PM
    BatesY
    ashland oregon
    so i have the same thing on my atv flag... so they dont have the spring... that thing hits me in the head so much i just dont want it to be rackin my truck everytime i shift to quick of brake to hard...
  6. Dec 8, 2008 at 1:13 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    then get a wilson "little will" magnetic roof mount antenna thats wat i have...
  7. Dec 8, 2008 at 1:17 PM
    BatesY
    ashland oregon
    firs stick als makes a short one like the magnetic one just mentioned but is a mounted in the bed type... do you think that will wack my cab?
    thanks for all the help i really appricete all the help!
  8. Dec 8, 2008 at 1:22 PM
    BatesY
    ashland oregon
    i was planing on cpnnecting it to the rail system on the cab side of the bed... like in the pic above but a shorter pole?
    whats the advantave of the longer pole? longer range or does it matter so much?
  9. Dec 8, 2008 at 1:27 PM
    BatesY
    ashland oregon
    do you need the antena? can you run it for a while with out one and just have really bad reception or do you need it?
  10. Dec 8, 2008 at 1:31 PM
    BatesY
    ashland oregon
    okay great thanks... so i really dont need it to be to tall or anything... yours you said was a short one and it works good?
    how long do you recomind?
  11. Dec 8, 2008 at 1:37 PM
    BatesY
    ashland oregon
    was the installation pretty easy?
    im trying to find the best way to route my wires and to get out of the cab for the pa and the antena
  12. Dec 8, 2008 at 1:39 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    I just ran all my stuff yesterday. I'll get some pics either tonight or tomorrow morning.
  13. Dec 8, 2008 at 1:42 PM
    BatesY
    ashland oregon
    that would be awesome thanks!:)
  14. Dec 8, 2008 at 1:44 PM
    FlawedXJ
    Paul
    NorAla
    I ran mine under the cab and thers a big drain hole plug that I pushed the wire through. Then i removed the driver seat and center console so I could run the wire into the glove box and mount everything in there.
  15. Dec 8, 2008 at 1:55 PM
    FlawedXJ
    Paul
    NorAla
    mines only 2 ft long and has a good at least mile range. Although I have a quick question. How do you ground the antenna itself.
  16. Dec 8, 2008 at 2:06 PM
    FlawedXJ
    Paul
    NorAla
    mines mounted like yours in the rail....Guess I'll have to run a ground for it. Will that help get rid of the constant static?
  17. Dec 8, 2008 at 2:23 PM
    FlawedXJ
    Paul
    NorAla
    It's not tunable. It was supposed to be "pre-tuned"
  18. Dec 8, 2008 at 2:36 PM
    FlawedXJ
    Paul
    NorAla
    would that be squelch? I got a cheap unit from walmart that has a volume knob and a squelch knob.
  19. Dec 8, 2008 at 2:40 PM
    FlawedXJ
    Paul
    NorAla
    yeah i was going to get a firestik and for some reason bought one from radio shack
  20. Dec 8, 2008 at 3:29 PM
    beehunt
    beehunt Well-Known Member
    Bay Area, Ca
    '08 TRD Sport Black Sand Pearl
    3in Level kit
    silverback, Did you have to run a ground down to the frame after you mounted it to the rail? If so do you have a pic of how you did it? I want to mount mine similar to yours but i am not sure if the rail counts as a ground any help is much appreciated.
    thanks in advance.
