C or E
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Popie Neil, Aug 20, 2018.
  1. Aug 20, 2018 at 4:31 AM
    Popie Neil
    Popie Neil [OP] New Member
    Neil
    16 Tacoma dbl cab sr5
    I going have to buy some replacement tires. I'm looking at Cooper at/3 . Gonna stay 245/75 16 . My question is should I go with p,Lt c range,or Lt range? Don't do much serious off- roading except hunting season . I haul a 18 bass boat on occasion and sometimes have a load of lumber ,tile ,ect. But not often , ride and mileage are important but it seems sometimes the stock hankook have a roll in curves.Any thoughts would be greatly appreciated!
  2. Aug 20, 2018 at 4:38 AM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Based on your use and frequency I would suggest C.
    Look at the load ratings in LBS for the tire comparisons, some E's I was looking at were only a ~300lb more capacity than a C. E do typically have a heavier sidewall for rock climbing.
    Wait for the next Ebay sale and buy some C's With a mfg rebate. I just put on 265/75/16 Hancock dynapro ATMs for $317. However I do like the looks of the new cooper at3 more.
    Good luck
    DrFunker likes this.
  3. Aug 20, 2018 at 4:39 AM
    DrFunker
    DrFunker Well-Known Member
    You shouldn't need E range tires.
  4. Aug 20, 2018 at 5:04 AM
    Popie Neil
    Neil
    Ok not E range but LT C range or P ?
  5. Aug 20, 2018 at 5:10 AM
    DrFunker
    I agree with surfandturf, look for something in C.
  6. Aug 20, 2018 at 5:27 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I honestly don't think it matters for your use. Find a tire that you like and is affordable and go for it.
    Not in all cases, but the P rating often has better mileage warranty than the LT tires.
  7. Aug 20, 2018 at 5:28 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    C there is no reason for an E rated tire on a Tacoma.
    CowboyTaco likes this.
  8. Aug 20, 2018 at 5:58 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    This might not help you, considering I stuck with STD load ... but the Cooper Discoverer AT3's were great tires for me. Lots of hwy driving, firewood hauling, A-liner Expedition towing over their 68k mile life.
    Great MPG's (exceeded 25 regularly when I was trying), excellent in the rain and snow.
    I probably had another 10k of life in them, but I got a flat ... and they had an uneven wear pattern due not keeping up with alignment like i should have.
    Have a new set of STD load AT3 4S on there now, and they have a bit more road noise ... but otherwise seem identical in MPG and rain performance to the regular AT3. They are too new for any more of a comparison.
  9. Aug 20, 2018 at 7:07 AM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Since you tow, go with C load. E would be overkill, IMO.
    P rated tires could do the job as well, just Not as well as the Cs for towing.
