C rated tire psi
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Discokiller, Sep 15, 2022.
  1. Sep 15, 2022 at 6:07 AM
    Discokiller
    Discokiller [OP] When short, sweet and sexy, what matters!
    Disco
    Tacoma sx
    Hello....have 265/75r16 cooper A/T on my taco...tire is C rated....max 44psi.... wondering what you guys normaly run your tires at? There at 32psi now.....daily driver...
  2. Sep 15, 2022 at 6:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    Google 'chalk test' and then determine your optimum PSI for your actual vehicle.
    Guessing your 32 will be close, but never hurts to fine tune.
  3. Sep 15, 2022 at 6:10 AM
    Discokiller
    Disco
    Tacoma sx
    Thanks...yes ive read about the chalk test....but just seeing what people say....
  4. Sep 15, 2022 at 6:49 AM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    What does your door jamb label say?
    Mark77 and ToyoTaco25 like this.
  5. Sep 15, 2022 at 6:50 AM
    GarrettTacoma
    GarrettTacoma Well-Known Member
    2022 2.7L SR DCSB 2022 TRD OR DCLB
    I recommend you try 36 psi front and 33 psi rear.
    Pixeltim and Backdoc like this.
  6. Sep 15, 2022 at 6:51 AM
    Discokiller
    Disco
    Tacoma sx
    Its not the oem tires!
  7. Sep 15, 2022 at 6:53 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Pay attention!
  8. Sep 15, 2022 at 6:54 AM
    CrispyTacoLover
    lol
    I was.
  9. Sep 15, 2022 at 6:55 AM
    dylanbike1
    dylanbike1 Well-Known Member
    Dylan
    2017 Tacoma TRD off road
    I settled on 34 front and 32 rear when warm for that size. Pressure can increase as much as 10-15% in peak summer from cold/parked in the morning to highway speeds in mid afternoon.
    I had C rated, Falken WildPeaks in that size on OEM (stock) wheels
  10. Sep 15, 2022 at 6:57 AM
    CrispyTacoLover
    If you check, and apparently that’s way too inconvenient for you, you’ll see you are 2 pounds from the Toyota recommendation.
    Mark77 likes this.
  11. Sep 15, 2022 at 7:01 AM
    Buck Henry
    Damn dude, why you gotta throw in that slam? She was asking a legit question here.
    RustyGreen likes this.
  12. Sep 15, 2022 at 7:03 AM
    Discokiller
    Disco
    Tacoma sx
    Well.... If you take the time to read my tires at the moment are at 32 psi... Which is what the factory recommendation is on the original tires! Since I'm not running the original tires I thought the gentleman on the line would be graceful enough to tell me what they prefer to run their tires at? Apparently that's an inconvenience for some as some are not gentleman!!!
  13. Sep 15, 2022 at 7:10 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    I'm at 30 psi on Duratracs all around.
  14. Sep 15, 2022 at 7:10 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    I run 35frt/33rr and adjust for load.
  15. Sep 15, 2022 at 7:14 AM
    Discokiller
    Disco
    Tacoma sx
    May i ask? Why the difference in front and back? Why not all the same?
  16. Sep 15, 2022 at 7:20 AM
    dylanbike1
    Dylan
    There is less weight in the rear of the truck with no load or light load. Often this will give the best compromise of contact patch wear, traction, and ride feel.
    The chalk test only takes a few mins and is the best way to optimize wear at home with no special equipment.
    Sterling_vH111 likes this.
  17. Sep 15, 2022 at 7:20 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    32 is fine.
  18. Sep 15, 2022 at 7:24 AM
    Discokiller
    Disco
    Tacoma sx
    When you say 32psi is fine....were talking when cold? Becuase 32psi will turn to 34psi when hot. Etc,etc....just to be learning correctly....
  19. Sep 15, 2022 at 7:25 AM
    That one old guy
    Chuck
    Stockish
    Unloaded, the weight bias favors front heavy. Loaded, that bias diminishes depending on weight of. Adjust rr PSI accordingly. 50/50 frt/rr ratio is considered optimal by most.
  20. Sep 15, 2022 at 7:43 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    You will get multiple different answers from people with multiple different factors. Start at what the door placard states and then adjust from there and see what feels right.
