C4 FAB '12-'15 Tacoma front Lo-Pro Winch bumper install instructions
Discussion in 'C4 Fabrication' started by C4 Fabrication, Oct 23, 2016.
  1. Oct 23, 2016 at 2:34 PM
    C4 Fabrication
    C4 Fabrication [OP] Well-Known Member Vendor
    Caleb
    South Dakota
    07 DCLB Sport
    2" lift, 285/70/17 BFG TA KO2's, baja bumper, bedrack with swing out, CVT RTT, Leather interior, heated seats, JBL, remote start, K&N intake, Hood Scoop LED lightbar mod.
    Hey everyone, here are the install instructions for our '12-'15 Tacoma Lo-Pro winch bumper.
    Tools required:
    Flathead screwdriver
    10mm wrench/socket
    12mm wrench/socket
    14mm wrench/socket
    17mm wrench/socket
    7/16" wrench/socket
    3/4" wrench/socket
    Jigsaw or tin snips to cut plastic bumper.
    Drill with 1/4" bit.
    1) First you will need to start by removing the plastic front bumper cover. You will need to remove the grille first and set it aside. Then remove the plastic bumper cover.
    Here is a link to a quick video that shows how to remove the bumper cover. The Tacoma in the video is an 05-11 model, but the process is the same.
    We did not make this video and are in no way taking credit for it. We are simply posting the link for easy access to the removal process.
    https://www.youtube.com/watch?v=MgGvdKexBqY
    Here is what the truck will look like once the grille and cover are removed.
    2) Once the plastic cover is removed, take the foam insert out of the back of the bumper cover and discard it. The bumper cover should look like this after the foam is taken out.
    3) Now the black plastic insert in the center of the bumper cover needs to be removed. Use a flat head screw driver to push down on the tab on the blue plastic clips on the inside of the bumper cover. Slide the clips out of their slot and then the center plastic piece can be removed.
    The next step is to cut out the plastic portion of the bumper that is no longer needed.
    4) Cut along the natural shape of the bumper right in this area to remove the plastic in the center of the bumper cover.
    The bumper should look like this after the cutting is complete.
    5) Clean up the edges of the cuts with a sanding pad on a dremel tool or die grinder. That is the only cutting that is required.
    6) Now remove the aluminum crash bar, frame end caps and tow hook from the truck.
    Use a 14mm socket and wrench or impact drill to remove the crash bar parts.
    Use the 17mm wrench or socket for the frame end caps.
    Also remove the tow hook.
    ChadsPride likes this.
  2. Oct 23, 2016 at 2:49 PM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    You can now re-install the plastic bumper cover and grille onto the truck.
    The cover will look like this after trimming and re-installing:
    You are now ready to install the Lo-Pro winch bumper.
    If you are using a winch and/or light bar inside the bumper, install them into the bumper first.
    1) Lift the Lo-Pro bumper up into place and attach it to the mounting studs where the aluminum crash bar used to be attached. Use the original hardware at this attachment point.
    2) Install the supplied 1/2"x1 1/2" bolt with flat washers and lock washer into each hole where the frame end caps used to be.
    Do not forgot to install the nut on the inside of the bumper as well.
    3) Now the plastic bumper cover needs to be attached to the small mounting tabs on the bottom side of the Lo-Pro bumper. Hold the plastic in place above the tab. Using the metal tab as a guide, drill a 1/4" hole up through the hole in the tab and through the plastic bumper cover.
    4) Install the supplied 1/4"x1" bolt and washers into the tab and through the hole in the plastic to hold the plastic cover in place.
    5) Do a final check to make sure all mounting bolts are tight and your installation is now complete!
    wi_taco, super_white and ChadsPride like this.
  3. Jan 27, 2017 at 4:59 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    As pictured, is that the 30" light bar cutout?
  4. Jan 28, 2017 at 10:33 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    yes it is.
  5. Mar 19, 2017 at 6:24 AM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    I have a question and was hoping someone could answer it for me. I have been looking at aftermarket bumpers for about a year. I am interested in the LO-Pro front bumper for the stock looking clean lines and weight. I am in the process of modifying my 2015 DCLB for alot of towing and want additional protection for the trans and oil coolers and it looks like to LO-Pro will provide some measure of protection. Last year in SW Colorado My brother-in-law hit a mule deer with a RAM 2500. It took out the AC and trans cooler which sidelined us. I know there is nothing foolproof in protecting against deer strikes but at lease if I can save the coolers I can limp to a dealer. I looked at the install pictures in this thread but I cannot see how much clearance there is between the bumper and Rad, AC coil, trans cooler. There is a TW thread with a Derale 52506 trans cooler installed and I will be installing one on my Taco. They are 44000 BTUs of cooling and will cover about half of the radiator. So here is the question; will a trans cooler that large fit behind the LO-Pro?
  6. Mar 20, 2017 at 8:09 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    I could not tell you for sure if there is room for that cooler to fit. Basically the bumper does not extend past the front face of the flat bumper mounting brackets on the front of the frame rails. I do not know for sure how much room is between the front face of the frame and the radiator.
  7. Mar 20, 2017 at 5:21 PM
    airsavage
    Butch
    Thanks for the quick response. As soon as I save some coin I will be ordering a LO-Pro.
  8. Mar 21, 2017 at 7:03 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    No problem, and we look forward to your order!
  9. Sep 3, 2017 at 5:18 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    How much these weight?
  10. Oct 1, 2017 at 6:41 PM
    Beardedtacoguy
    Beardedtacoguy Member
    Kevin
    2015 TRD off-road
    Too many
    Will a 30" rigid industries single row fit?
  11. Oct 12, 2017 at 1:55 PM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    About 70lbs
    The bumper is not designed for the Rigid 30" single row, but from what I can tell from measurements, it should work. You will just have to put a couple washers between our light mounts that are welded into the bumper and the mounting tabs that come with the light. The rigid light tabs are shorter than the baja designs so you need to space them up to get the light to center in the cutout.
  12. Oct 12, 2017 at 3:53 PM
    Beardedtacoguy
    Kevin
    2015 TRD off-road
    Too many
    Thanks.. reason I ask is because I already have the rigid bar on my truck and I will be ordering the bumper soon and wanted to swap my current bar into it.. appreciate the info
  13. Jun 13, 2019 at 5:19 PM
    Avrxlius
    Avrxlius Member
    High Rockies
    2015 Inferno Tacoma TRD Pro
    Fox 2.5 Extended Travel Coilovers // Fox 2.5 Reservoir Shocks // Icon Mult-Rate RXT Leafs // Enkei RPT1 16 Bronze // Falken Wildpeak AT3W 285/75R16 // ECGS Clamshell CV Axle Bushing // Wheeler's U-Bolt Flip Kit // Wheeler's SuperBump Stops // Wheeler's Axle Shim // ARB Carrier Bearing Drop Kit // SwitchPros SP9100 // WeBoost Drive Reach // Meso Customs BD3-NMO Ultimate 3rd Brake Light // Garmin Mini Dash Cam + Polarized Filter // SDHQ Battery Terminals // CBI Al Full Skid Plates // SOS Streamline Al Bumper // Warn VR EVO 10-S Winch // Factor 55 Flatlink E + Rope Guard // Factor 55 Hawse Fairlead 1.5 // Cascadia 4x4 Flipster V2 // BPF HD Recovery Tow Hook // SDHQ ABS Guards // Baja Designs Squadron Sport Amber Fog Lights // Line-X'd Bed // Bak Revolver X4 // Total Chaos Bed Stiffeners // Meso Customs Gasshole // Hella Supertone Horns // PIAA G3 Headlight LEDs // VLED Indicator, Turn, Reverse // Spotter Mirrors // TRD Oil Cap // TRD Coolant Cap // Manifold Air Injection System K&N Filter // K&N Cabin Air Filter // Carhartt Precision Fit Seat Covers
    Hey, I'm interested in this bumper. I've already called Kylie at C4 a couple times, but the more I look into this, the more questions I come up with...
    Can the Lo-Pro bumper be installed without removing the OEM plastic...can the disposable section be cut off while on the car, like in the "2005 - 2011 Tacoma Lo Pro Bumper Install" YouTube video?
    Will the Toyota OEM skid plate PT212-35075 go on over this Lo-Pro bumper? Can the OEM tow hook be reinstalled?
    @Beardedtacoguy , @airsavage , did you install? How did it go? How does it look? Recommended?
    Thanks for all your help guys!
  14. Jul 1, 2019 at 9:37 AM
    C4 Fabrication
    Caleb
    South Dakota
    07 DCLB Sport
    Hi,
    you may be able to cut the plastic and install the bumper the same way we did on the 05-11 Tacoma Lo-Pro. We haven't actually tried one yet but I think it would work that way.
    The OEM skidplate should work fine.
    The OEM tow hook cannot be re-installed, but you wont need it anyways now that you have the tow hooks integrated into the bumper.
  15. Aug 9, 2019 at 12:09 PM
    Rodrigo209
    Rodrigo209 New Member
    Rodrigo
    2006 tacoma
    I got a 06 Tacoma with a 2015 front end does the bumper fit?
    JakeSeig likes this.
  16. Feb 22, 2020 at 9:25 PM
    Bobcdn
    Bobcdn Well-Known Member
    WTB; 2nd gen well built Tacoma
    Wondering if someone could tell me the dimensions of the OEM front crash bar?
    How tall is it and how thick? I am going to guess it is 4" high by 2" thick???
    Thanks.
  17. Mar 14, 2020 at 5:44 AM
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    Just installed mine yesterday. Nice and easy install!
    super_white, banditcamp and huli467 like this.
  18. Jan 8, 2022 at 12:07 PM
    STLTaco
    STLTaco New Member
    2012 Tacoma TRD Off Road
    Is this still available? Can’t seem to find it on C4 website. Hopefully just looking in the wrong place.
    tha is,
    Andy from STL
  19. Jan 19, 2022 at 5:51 AM
    Hawapino
    Hawapino Well-Known Member
    Ivan
    Denton, Tx
    2015 Super White DCSB TRD OR 6MT
  20. Jan 19, 2022 at 6:32 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Hope not. It’s on my short list of lo pro winch bumpers.
