C4 FAB '16+ Tacoma Overland Series Hi-Clearance rear bumper installation instructions
Discussion in 'C4 Fabrication' started by C4 Fabrication, Aug 11, 2016.
  1. May 29, 2020 at 9:27 PM
    #101
    SubaruTheTacoma
    SubaruTheTacoma Subaru Tacoma STI
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    Derp on me I totally forgot to update.
    I bought the ones from ruff stuff. Worked great easy to replace and the new ones come with a lock to leave it twisted up. I feel like that’s more dangerous. I rather break another pin over let the gate slam against the gas spring? Or worse?
    any way I got 2 pins and leave one in the cubby of my truck bed in case I break another one in the wild
  2. Nov 16, 2020 at 1:56 AM
    #102
    jardoo
    jardoo Well-Known Member
    Houston, Texas
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    So I just installed my rear bumper but the support brackets are updated and not like the ones displaced in the instructions here. How do i install them? and which bolts do i use?
    Thank you.
    Also, what are these for?
  3. Nov 16, 2020 at 7:17 AM
    #103
    jardoo
    Houston, Texas
    can anyone help please?
    Thank you
  4. Nov 16, 2020 at 10:11 AM
    #104
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    I believe cutouts are for different lighting options. I didn't end up using them and was able to install my Baja design lights without them. I didn't use them because when I sent all of my pieces to get powder coated those pieces weren't powder coated so I left them off.
    As for the support brackets, there is really only one orientation that they fit/lineup in. I just took both support brackets and tried them in different orientations until they lined up accordingly. I'd go take pictures but don't want to deal with snow on the ground.
    jardoo likes this.
  5. Nov 16, 2020 at 2:26 PM
    #105
    3Six
    3Six Well-Known Member
    Icon Stage 4, Method NV 305, 285/75/16 Wildpeaks, Pelfry Armo, CMC
    The offset mounting holes are bolted to the bumper near the spot where you'd find the other support brackets. You'll line them up against the frame, then mark the frame to drill. I can take a photo if needed.
    jardoo likes this.
  6. Nov 16, 2020 at 2:30 PM
    #106
    3Six
    jardoo and H3llRid3r like this.
  7. Nov 16, 2020 at 10:49 PM
    #107
    jardoo
    Houston, Texas
    Got it all done. Thanks for the help guys.
    3Six likes this.
