C59-314 or C59-352 Dobinsons springs for this setup? Experiences?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hoodwinked, Apr 18, 2024.
  1. Apr 18, 2024 at 12:06 PM
    hoodwinked
    hoodwinked [OP] Well-Known Member
    Hello all,
    I did some forum digging but couldn't find an answer as it seems to be an opinion more than a science.
    Going to be running a C4 lo-pro front bumper with smittybilt winch and light bar. I estimate ~160lbs up front with these. The question is C59-314 or C59-352 Dobinsons springs? Looking for 2-2.5 inch lift. I understand I can go C59-314 and add some preload to get to that height, or just run the C59-352 which should put me at about 2" with the added weight and no preload.
    Looking for a somewhat comfy on-road ride. I heard the heavy rate can be a little stiff. Anyone running either spring with similar weight that can chime in with their experiences?
    Thank you!
  2. Apr 20, 2024 at 12:18 AM
    hoodwinked
    bump for opinions?
  3. Oct 31, 2024 at 3:02 PM
    bttrbsch
    bttrbsch Well-Known Member
    Michael
    Bellingham, WA
    2018 Inferno Tacoma TRD Off-Road
    Kicker speaker upgrade Rockford Sub TRD Grill Raptor Lights Oedro Running Boards Seat Covers Black Emblems MBRP Exhaust Sound dampened doors Blacked out turn signals Pro comp 7069 wheels BFG KO2 285/70/17 Ram mount Joying Head Unit Fogs Soft topper canopy Fox 2.5 RR DSC Fox 2.0 RR rear HS AAL 1.5" rear plus overload (2" total) Center console divider Axe/Shovel Mount Traction boards 32" light bar Shift sense pro v2 iDrive throttle controller Xentec 35W HIDs Vair 88p air compressor Dome LEDs LED reverse lights + pods JBA Upper Control Arms Full size spare tire Driver seat riser
    What did you end up going with? Dobinsons recommends the C59-314 spring with the preload set at 1/2" for 2.5" of lift for a similar setup (3rd gen with ~100 lbs. up front).
  4. Oct 31, 2024 at 3:38 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It would help if you posted specs for the springs you are asking about, ie spring rate and length. Brand names and part numbers require the reader to do research.
  5. Nov 2, 2024 at 8:32 PM
    hoodwinked
    I went with the C59-352 in the end. No preload.
    Total weight up front is about ~160 lbs. C4 Lo Pro bumper, winch, and light bar. I like the ride, not too stiff. Definitely much firmer than stock.
    Looks to be about 2" of lift, as expected by the specs on Exit Off Road's site.
  6. Nov 3, 2024 at 9:39 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    According to CrikeyMike's TW posted specs, that 352 spring is 730 lb., 385 mm length.
  7. Nov 3, 2024 at 1:09 PM
    hoodwinked
    I was going by this on his page for Exit Off Road:
    Select Front Coils
    Note: Access Cab models come with 1" lift from the factory. Deduct 1" lift from the lifted heights, or add longer/taller struts to regain that 1"
    C59-238 - 0-1/4" lift Closest to stock height
    C59-300 - 1" Lift with stock front end
    C59-302 - 1.6" Lift stock front end, 1.25" with light bumper OR winch
    C59-314 - 2" lift stock front end, 1.75" with 100LBS
    C59-350 - 1.5" to 1.75" with 110-220LBS, 2" with stock weight (heavy rate)
    C59-352 - 2" lift with 110-220 lbs, or 2.5" with stock weight (heavy rate)
    C59-354 - 2.4" lift with 110-220LBS, or 2" with 230-300LBS (heavy rate)
    C59-318 - 3.0" lift with 110-220LBS (heavy rate)
  8. Nov 3, 2024 at 2:42 PM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
  9. Nov 3, 2024 at 10:36 PM
    bttrbsch
    Michael
    Bellingham, WA
    Thanks for the info!! I reached out to CrikeyMike and he confirmed that C59-314 with 1/2" of preload should work. I would rather have a soft ride than too harsh.
  10. Feb 10, 2025 at 5:29 PM
    hoodwinked
    Curious what you ended up going with for Dobinsons springs.
  11. Feb 10, 2025 at 10:08 PM
    bttrbsch
    Michael
    Bellingham, WA
    Funny you would respond 3 months later, which just so happens to be 24h after I installed the coilovers. I went with the 314 coils, 1/2" of preload. I initially measured 25" from center of hub to fender, it has since settled to 23". I don't have more than 100 lb. weight up front. Going in for alignment tomorrow.
    Rides nice. I have the adjusters completely open and will do more tinkering in the coming weeks.
  12. Feb 10, 2025 at 10:22 PM
    hoodwinked
    Haha nice, good timing. How much lift did that give you after it settled? Did you do a before measurement?
  13. Feb 10, 2025 at 10:25 PM
    bttrbsch
    Michael
    Bellingham, WA
    Unfortunately I did not grab a before measurement. I have installed several lifts on the truck and have lost track at this point. I would say 2".
  14. Feb 11, 2025 at 11:12 PM
    hoodwinked
    Do they feel firmer than stock? Stock was pretty bouncy. I was concerned the 314 spring would not have been the right choice for ~150lbs. Perhaps I was wrong.
  15. Feb 12, 2025 at 7:58 AM
    Mrcooperou812
    Las Vegas NV
    2016 DCSB OR 4WD
    Around 21" hub center to fender edge is 3rd Gen stock front height, so 23" would be 2".
    I noticed that Mike's TW product posts for 2nd Gen suspension offerings and then for 3rd Gen suspension offerings, are the same springs, and the description for the 314 springs is the only one that changed.
  16. Feb 12, 2025 at 1:32 PM
    bttrbsch
    Michael
    Bellingham, WA
    I haven't had stock suspension since 2019, but over the 4 suspension packages I've had on the truck I like these the best and plan to keep them on permanently. Yes, they are firmer than stock but not harsh. I bet the 314 spring is perfect, I'm very happy in the couple days of driving since installing this weekend.
  17. Feb 12, 2025 at 1:32 PM
    bttrbsch
    Michael
    Bellingham, WA
    Agreed. I was shocked how much the springs settled after install, but 23" up front is ideal for me.
