CA SMOG Fuel Cell
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004Taco, Jul 12, 2021.
  1. Jul 15, 2021 at 6:43 PM
    #41
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Ya, and things like tuning engines (to make them more efficient, because that's the way the tune makes them more powerful) is totally going to cause the smog issue to get worse.
    Just like adding a cold air intake with no sticker, that's exactly the same as the other cold air intake that does have a sticker sitting on the same work bench... is going to make the smog get worse.
    Or replacing a gas tank with a fuel cell is going to drape a layer of smog over LA.
    Or swapping a NEWER MOTOR (fuel injected) from a Chevy to replace an OLDER MOTOR (carburated) from a Toyota Truck is going to make smog get worse.
    The smog laws governing modifications have had almost ZERO impact on the smog situation. Advancements and higher efficiency in the new cars is what has had an impact on smog.
  2. Jul 16, 2021 at 6:11 AM
    #42
    2004Taco
    2004Taco [OP] Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    @jbrandt
    Alright, I spoke with my regular STAR cert. SMOG guy yesterday. I told him what I was doing for suspension and I need to replace my gas tank with a different GAS TANK to accommodate the 4 link. I showed him pictures of other prerunners that had similar set ups. I made it clear that I was going to either buy or have a GAS TANK made, not a fuel cell. I didn't even say fuel cell because that's not what I'm going to be installing. He said that if all the evap stuff and charcoal canister is installed just how it would be stock, he doesn't care and that he doesn't even look at the gas tank.
    jbrandt likes this.
  3. Jul 16, 2021 at 8:20 AM
    #43
    soggyBottom
    soggyBottom Well-Known Member
    That sounds reasonable.
  4. Jul 16, 2021 at 8:29 AM
    #44
    soggyBottom
    I agree with most of that but people abuse it. There are good tunes and bad tunes. For example, OVTuned refuses to offer ultra lean tunes because of increased NOX despite getting better fuel economy. From what OP said in his last post, it doesn't sound like the fuel cell is that big of a deal as long as the emissions equipment is installed with the new system.
  5. Jul 18, 2021 at 9:10 AM
    #45
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Ya sounds about how my Smog guy was with my F150 tank behind the rear axle. I just scabbed all the Toyota stuff into the new tank, works like stock! They have bigger (deeper mainly) tanks too, up to 25 gallons I believe.
    2004Taco[OP] likes this.
  6. Jul 19, 2021 at 8:45 AM
    #46
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I mean, I'm not, but okay.
    Do you know what inflation is?
    You also realize that the gas tax isn't the only way roads and infrastructure are paid for, right?
  7. Aug 29, 2021 at 3:24 PM
    #47
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Any smog "guy" would pass it.
    MadNachos likes this.
  8. Jun 13, 2022 at 5:48 AM
    #48
    Arman Bagdasarov
    Arman Bagdasarov armbag
    2001 4x4 Tacoma
    Camburg UCA, King coil overs, Fox Shox, Deaver springs, BAMF sliders & LCA Skids, Relentless Skids. Lights on lights on lights
    do you have more details on how you do this or a write up?? Need to relocate my tank to the rear and I was looking into an F150 tank
  9. Jun 13, 2022 at 6:24 PM
    #49
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    "I had a friend" that could get it done via SMS back about 6 years ago. Pretty sure they found 'em on CL.
  10. Jun 16, 2022 at 9:07 AM
    #50
    thegame
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    No write up really. Just follow these easy steps
    Buy F150 tank
    Cut out F150 pump mount
    Buy sheet metal and weld in place of F150 pump mount
    Cut Tacoma flanges off the stock tank and weld to F150 tank
    Cut fuel pump bucket out of the stock tank and weld to F150 tank
    Shorten Tacoma fuel pump bracket and float arm
    Or buy an F150 tank and F150 sending unit (with the built in baffle) but your gas gauge will read backwards.
