CAB Antenna location
Discussion in '3rd Gen. Tacomas (2016-2023)' started by geekyadam, Aug 5, 2017.
  1. Aug 5, 2017 at 7:48 AM
    geekyadam
    geekyadam [OP] Game Master
    Adam
    Northern Virginia
    17 SPT MT DCSB
    OME lift, 3leaf AAL, uniball UCAs, 3° shims, CV bushing, U-bolt flip + Superbumps, sway bar relocate, Cooper Discoverer AT3 XLT 33s, cosmetics
    Looking for recommendations and pictures of where you guys put your CAB antenna on your 3rd gens. I'm putting a magnet base on top of my cab for now but want to mount a nice one somewhere permanently. Where do you guys mount your antennas?
  2. Aug 15, 2017 at 4:21 PM
    blackcloud08
    blackcloud08 Well-Known Member
    WNC
    Reviving this, would like to know if there are any brackets out there to use with a mag mount. My truck has a bed cover so I'm limited in options.
    geekyadam[OP] likes this.
  3. Oct 21, 2017 at 1:52 PM
    Photocycler
    Photocycler Well-Known Member
    Pacific Northwest
    2017 Tacoma TRD OR DHSB MGM
    Did you ever install it? I’m wondering how you ran the wires into the cab?
  4. Oct 21, 2017 at 2:46 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Behind the back seat there is several rubber gromets to run the wire into cab
  5. Oct 25, 2017 at 9:18 PM
    geekyadam
    Adam
    Northern Virginia
    17 SPT MT DCSB
    For my magnet mount I just ran the cable in through the rear window and along the upper trim pieces. I wanted a temporary solution as I don't plan on leaving it there. I think I'm going to go with a tailgate area mount, at least that's the look I like. C4 makes a tailgate mount, but they're $35 each and only available via a forum post I found here:
    https://www.tacomaworld.com/threads/cb-ham-radio-tailgate-antenna-led-pod-mount-by-c4-fab.459291/
    I need to finally get a welder for an upcoming project so I might just cut out a little piece of metal myself and bend it for the tailgate rather than pay $35 for a little piece of metal. Might take me a few attempts but could be fun project and DIY tutorial write up...
    I think the tailgate mount for the CB on one side and 2M HAM antenna on the other side would look cool.
  6. May 14, 2018 at 8:58 AM
    doyledoonz
    doyledoonz Active Member
    Kyle
    Ogden, Utah
    2017 Tacoma TRDOR DCSB
    Did any of you guys have any luck with the magnetic mounts? I got the K40 magnet mount, and the SWR was hovering around 6.0 no matter where I placed it. They are sending me another currently, assuming it's malfunctioning, but I assumed we don't have a big enough ground plane for SWR <2. In case you're wondering, I did check for continuity across positive/ground, and for a signal from radio to antenna, and everything appears to be working, aside from insane SWR.
    I'm in the same boat - I have a shell on the rear, so limited on options. I'm thinking of going the NGP firestik route unless the magnet mounts have worked for anyone here...
