Cab Mount Chop or no?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryank 5, Oct 30, 2014.
  1. Oct 30, 2014 at 7:23 PM
    ryank 5
    ryank 5 [OP] Well-Known Member
    Jefferson County, PA
    2006 Radiant Red Taco - Access Cab 4WD TRD
    OME Dakars, OME 884's, 5100's all around (0" setting), SPC UCA's, 17" 4-Runner Trail Edition Wheels with Dynapro's, ABS Killswitch Mod, Extang Tonneau
    Hey guys. Just ordered the 5100's. I reallly wanna fit 285 70-16 nitto trail grapplers in it. I know I'm gonna have to do some trimming, but do you think I'll have to do a CMC on the highest 5100 setting? I have Kmc hoss wheels at 0 offset and 4.5 bs. If I can't fit them without the CMC, I'm probably gonna go down to 265 wrangler mt/r's. Also, would 285/70 have a better chance of fitting than 285/75? Or is it strictly tire width?
  2. Oct 30, 2014 at 7:59 PM
    ryank 5
    I'm not looking to go 285/75. Just 285/70. So if I were to get the tires and 5100's put on, I should ask them to set the castor to 1.8? Or should I just ask them to adjust it so it doesn't hit the cab mount? I definitely want an alignment because my truck shakes like crazy
  3. Oct 30, 2014 at 8:33 PM
    ryank 5
    Alright thanks a lot guys. Do you think the shop would do the chop and patch?
  4. Oct 31, 2014 at 6:13 AM
    ryank 5
    I'm from western PA. I go to PSU but that's all the farther east I go. But your patch does look good. My dad's a retired welder, so I figured I'd see if the shops would do it before I go filling his lungs up with smoke. haha
  5. Oct 31, 2014 at 6:16 AM
    Large
    Large Red
    With that size tire and 2.5" of front lift you don't need to trim anything and you don't need a CMC. I ran that same tire, flexed fully while stuffed lock to lock and did not rub anywhere with 2.5" of front lift.
    Let me edit this, I had 4.5" backspaced wheels, not OEM wheels.
    Different size tires...
