Cab mount chop question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JethroFF, May 24, 2018.
  1. May 24, 2018 at 9:32 PM
    JethroFF
    JethroFF [OP] Well-Known Member
    2017 Inferno DCLB OR
    The shop that is doing my cab mount chop says they reuse the metal they cut away as the filler plate to seal the hole back up. Does this make sense? Any opinions?
  2. May 24, 2018 at 9:34 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    It’s all metal it won’t matter if it’s that or 14 gauge. I never capped mine because it’s easier to clean and I wouldn’t be able to remove the rubber bushing.
  3. May 24, 2018 at 10:06 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    I don't see why that wouldn't work - especially since it's something they always do apparently
  4. May 24, 2018 at 10:11 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    Guessing it's to help look stock.
  5. May 24, 2018 at 10:14 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Hahaha good one
    Rob Daman[QUOTED] likes this.
  6. May 24, 2018 at 10:27 PM
    JethroFF
    Thank you guys I feel better about it now just hadn’t heard of doing it this way
  7. May 25, 2018 at 4:51 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    That doesn't sound right.. How did they take a rounded corner cut off and make it a flat plate?
