Cab mount chop with 285's, even with 4"bs wheels
Discussion in 'Suspension' started by spartanhockey6, Dec 17, 2012.
  1. Dec 17, 2012 at 4:25 PM
    spartanhockey6
    spartanhockey6 [OP] My truck rattles, A LOT.
    Trevor
    Talent, OR
    2010 White Trd Sport
    Money Pit
    Okay, been thinking long and hard about lifting the taco. I wanna go with OME's in the front with the 13mm spacer for a full 3", the whole reason why i want to lift is to of course fit bigger tires....
    My question is about rubbing issues with 285's, i couldn't find a straight forward answer in the threads.
    If i get wheels with 4" backspacing R16 (wheelers offroad steelies) and throw some 285/70/16's on them will i still have to Cab mount chop? I'm aware that i will have to trim some of my fender.
    Thanks for your time guys!
    EDIT: Read that with wheel spacers someone didnt need the cab mount chop, but i'm trying to avoid wheel spacers.
    - Trevor
  2. Dec 17, 2012 at 4:35 PM
    87FoRunner
    87FoRunner MallTaco
    Cameron
    Memphis, TN
    05 TRD 4x4
    ARB. M8000. OME 886. Mickey Thompson Classic Locks. 285 Pro Comp XMT. Pioneer x930bt. Memphis SQ comps. Memphis S class 10. Kragen HIDs.
    You won't know until they are on there.
    285 70 16?
  3. Dec 17, 2012 at 4:54 PM
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    I will agree with this. Every truck seems to come out a little differant. I have 3" of lift with eibachs and 5100's with top plate spacers and LR UCAs. My rims have 4.5bs. 285 75 16 with only minor rubbing in the front of fender well. I have wheeled it a little and I dont think I will need to chop the cab mount. It might rub a little at full flex, but not enough to cut it up. I have read about lots of others. It works for some and not for others. Dont know WTF. Good Luck!
    PS I used to live in Medford. I would come to Ashland on the weekends for breakfast at the BreadBoard. YUM
  4. Dec 17, 2012 at 5:04 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Im not positive about this but with less backspacing i think you are more likely to rub on the cab mount. If you push the tire further out it increases the turning radius. Am i right about this? So if you have 4" backspacing vs. 4.5 you are more likely to rub i think.
  5. Dec 17, 2012 at 5:08 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Less backspacing == more likely to rub on fenders, cab mount, etc...
    More backspacing == more likely to rub tire on upper control arm.
  6. Dec 17, 2012 at 5:09 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I believe this is right. ^^^^^
  7. Dec 17, 2012 at 5:11 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Also, you're less likely to rub with a 285/70R16 (if you can even FIND such a tire) because that's a smaller tire than most folks run with a 3" lift. Typically in that case folks run either 285/75R16 or 285/70R17.
  8. Dec 17, 2012 at 5:13 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I am not too sure about how the backspacing with affect cab mount rubbing, but what you say makes sense to me Evanmb. That said, I also suspect the way your alignment is set would also have some affect on where and how much rubbing you will get. As stated earlier, you likely can't know for sure until you try putting them on.
  9. Dec 17, 2012 at 5:17 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK, you couldn't find a straight answer because every truck is a little different and every owner is a little different.
    Some folks don't wanna rub even at full compression at full lock. That's a *very* tough call to achieve and they'll end up trimming the absolute max.
    Some folks drive relatively gently, never even turn to full lock, and don't have a delicate ear listening out for rubbing. Mild rubbing, after all, is often difficult to detect.
    Aside from all that - how the truck is aligned after the lift is installed has a pretty big impact. The alignement cams can move the wheel in the wheelwell forward and backward by an inch or so. You can see where that can make a pretty big difference no?
    For myself, I didn't trim my cab mount until after I installed new upper control arms. Of course, before that, my alignment was running at a caster angle of roughly right around zero degrees, which made the truck drive kinda "twitchy" or "skittish" for want of a better word.
  10. Dec 17, 2012 at 5:21 PM
    Hairy Taco
    North of Hell
    08 TRD
    ^^^that is the goods^^
  11. Dec 17, 2012 at 5:35 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Sorry to thread jack OP. Steve, awesome right up on the OME installation, it has helped me alot. I finished the front yesterday and as we speak i am putting in my dakars.
  12. Dec 17, 2012 at 9:00 PM
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    First of all, Thanks to all of you who replied, I'm serious about lifting my truck and I wanna do it the right way the first time.
    Basically I wanna run a 33" tire with an x"width, I don't even know how guys are running 35's with 3" lifts. I really like maxamillion's taco and he's running 35's if I'm correct. I just don't want to have to re-gear. If it comes down to it I'm willing to do the cab mount chop though.
    The reason why I would get 4"bs wheels is for a less chance of rubbing as some of you guys said. Thanks for your guy's input as it would be annoying to pm everyone who has 3" of lift and 33's.
  13. Dec 17, 2012 at 9:03 PM
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    I forgot to mention I will be wheeling more when I lift so it's important to not rub at full lock and such haha.
  14. Dec 17, 2012 at 9:04 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Glad I could help. :)
  15. Dec 17, 2012 at 10:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    It's not a matter of being willing to do it, If you go larger than 265/75/16 or 17, You ARE going to be chopping the cab mount... period... as well as trimming a fair amount of plastic in & around the inner skirts of fender wells.... pretty straight forward answer huh ?....:)
  16. Dec 18, 2012 at 5:41 PM
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    Very straight forward..haha. looks like i'm going to the hardware store to get some things..
  17. Jan 13, 2013 at 11:13 AM
    DevL
    DevL Well-Known Member
    Running 33" or larger tires? Using a uniball UCA that adds caster? You will likely have some small rubbing issues AFTER the cab mount chop.
    I had to put caster over 3 degrees and REALLY flatten the pinch weld... plus extra plastic trimming.
  18. Jan 13, 2013 at 11:48 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Im running ome, toytec top spacer, lr upper control arms. Runn nitto trail grapplers durring summer, 285/75r16. Rims 4.5 back spacing. My tires rubbed on body mounts. Did the chop and a full lock no more rub. This summer switching rims to 4.75 bs with 1.25 spacer ill get back to u on that lol
  19. Jan 13, 2013 at 12:25 PM
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    Thanks for all the input guys.
    You got a nice looking truck man! Gotta love the AC's.
  20. Jan 13, 2013 at 12:39 PM
    spartanhockey6
    Trevor
    Talent, OR
    Money Pit
    Just now saw this haha. Yeah the Breadboard is bomb! Or was bomb, it's still good but has gone downhill. That's how it is with a lot of the restaurants here now. I was working at Callahans lodge right off the Mt. A exit for awhile.
