Cab Mount Chop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by veet skeet, Feb 2, 2012.
  1. Feb 2, 2012 at 11:31 AM
    veet skeet
    veet skeet [OP] Well-Known Member
    Cali
    14 4Runner Trail Edition MGM
    Bilstein 5100s, 17' Method NV Race Wheels, Goodyear Duratrac 265/70/17, Demello Sliders, Xenon/LEDs All Around, Dark Window Tint, Gobi Roof Rack (In the Mail), JL Audio Subs, Alpine Speakers and Amps
    Hey guys, just got my 17' Ballistic Jester rims on, with 4.5 inch backspace and -12 offset. I am running a 265/70/17 Nitto Terra Grappler with it, and the tires rub when I am in reverse full lock.
    I am looking to get a cab mount chop with the welded piece to cover up where it was chopped. Anybody know where I can get this done in SoCal?
  2. Feb 2, 2012 at 11:43 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Im surprised you hit the cab mount With 31 Are you sure it's not rubbing the fender
  3. Feb 2, 2012 at 11:49 AM
    veet skeet
    Cali
    It's rubbing against the front of the front fender area at reverse full lock. I have no clue if it is or isn't the cab mount exactly but I assumed that it was.
  4. Feb 2, 2012 at 11:54 AM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    The cab mount is at the rear of the fender
  5. Feb 2, 2012 at 11:56 AM
    Buell
    Buell Instagram: @thebuell
    Michael
    Culver City/Santa Monica
    2011 TX Pro MGM 4x4 Tacoma DC
    KR Fab, does exactly what you are looking for, I got it done there in less than an hour. Just set an appointment and he'll hook u up. He's in Lancaster, CA
  6. Feb 2, 2012 at 11:57 AM
    BAMFTACO
    Juan
    I think you might be rubbing on the fender but dont quote me just search for cab mount chop and theres tons of threads on this
  7. Feb 2, 2012 at 11:58 AM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    285/70/17 Goodyear BFG KM2's, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Probably going to have to cut the inner plastic fender well a little bit. You can use a sharp razor or knife to do this. The stuff is easy to cut.
  8. Feb 2, 2012 at 12:02 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  9. Feb 2, 2012 at 12:04 PM
    veet skeet
    Cali
    Anyone have pictures of cutting the inner plastic towards the front of the front fenders?
    And if I cut the plastic, do I have to cover it up with anything?
  10. Feb 2, 2012 at 12:17 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    OMG!!! LOL :goingcrazy: Good thing you posted on here before you went to a shop and asked for them to chop the mount just to find out that you didn't even fix the problem! Get out of the truck and turn your wheel and look to see where the closest areas are and go from there. I'm running 295/75/16 with zero rubbing at all. i'm on 3" of lift though and still have plenty of room before I hit the cab mount.
  11. Feb 2, 2012 at 12:33 PM
    veet skeet
    Cali
    Yeah seriously I am lucky I posted first before doing it! i just need to figure out if I need to cover up the hole in the plastic after cutting it so that my tire does not rub.
  12. Feb 2, 2012 at 12:40 PM
    DevL
    DevL Well-Known Member
    First you will need to trim plastic... inner lip of the fender and some of the fender liner. Front and rear of the wheel well. If you still rub you wil need to hammer over your pinch weld at the rear. If you rub the cab mount you will need to chop that. You have a good inch or more after initial contact of plastic before you contact the cab mount.
