Cab rust - Options.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BluberryBCtaco, Aug 8, 2023.
  1. Aug 9, 2023 at 2:57 PM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    I'd go the cheap route. Cut to clean metal, wire wheel what you can, spray rust converter on the rest then drown it in Cosmoline and plug it.
    Unless you're planning on keeping the truck another 20 years, in which case I'd go the expensive route. Drop it off at a body shop and get a warranty on the repair.
  2. Aug 9, 2023 at 3:21 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My 08 did the same but worse.
    I also use lps3 wish I’d had pulled the rocker plugs and coated the inside.
    Check your cab mounts.
    Mine was 12yrs old and 200k I cut the rot and put on a patch with self tappers and seam seal. I spayed the shit out of it inside before closing it up. It got a new frame 1yr before and was totaled 1yr after, kid ran a red and T-boned it dammit!
  3. Aug 10, 2023 at 5:39 AM
    91859706
    91859706 I like Toyota trucks.
    Ithaca, NY
    2006 DCSB TRD OR
    I am currently fixing my rockers which have similar but worse rust than yours OP.
    I’ll post a link to my “build thread” where I’ve documented the fix.
    basically you’ll cut out the rust back to good metal (a dremel with cut off shell fits nicely in there), then weld in a new patch. I used Eastwood alumnized steel patches.
    Start at post #21 (or read the whole thread)
    https://www.tacomaworld.com/threads...ing-a-car-payment.802807/page-2#post-28942092
  4. Aug 10, 2023 at 5:45 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Pretty standard for here in the rust belt. If your truck is 10 years old with no body rust, you're doing something right. 20 year old trucks rarely have rocker panels any longer.
    Too Stroked likes this.
