Cabin air does not flow well.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Railfan8888, Jan 28, 2023.
  1. Jan 28, 2023 at 11:09 AM
    Railfan8888
    Railfan8888 [OP] New Member
    Silver 2011 Tacoma TRD Sport
    The fan works fine and you can audibly hear it change speeds. As the fan speed increases, air flow stays the same. Both cool and hot work. And the filter has been replaced recently.
    Is there a possible blockage in the ducts?
  2. Jan 28, 2023 at 11:22 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Possibly if you have had rodents in your truck. The other possibility is your air intake for the cabin is clogged ,it's under your windshield wipers.
  3. Jan 28, 2023 at 11:30 AM
    Railfan8888
    There isn't anything covering the vents under the wind shield wipers. Besides taking the air filter out from the cabin, is there another way to see into the ducts?
  4. Jan 28, 2023 at 11:34 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Did it reduce flow after the filter change?
    I've noticed that some of the "nicer" filters restrict flow so much they're useless. I use 10 dollar cheap ass filters because they're the only ones that the blower can handle. Try buying one of those, the very bottom bargain bin filter.
    winkel and davidstacoma like this.
  5. Jan 28, 2023 at 11:35 AM
    MGMDesertTaco
    Blower motor might be on its way out.
  6. Jan 28, 2023 at 11:35 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Pull the filter and see if it improves.
    goforbroke123 and Rick's 2012 like this.
  7. Jan 28, 2023 at 12:51 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Our A/C isn’t great; there are several other threads about our blower being weak even on high.
    goforbroke123 likes this.
  8. Jan 28, 2023 at 12:52 PM
    Railfan8888
    Ok, thanks for the feedback
  9. Jan 28, 2023 at 1:23 PM
    DJSpeed
    DJSpeed Well-Known Member
    best bet is to pull the filter. ORRRRR... the cover wasnt put on securely when they replaced it so you still not getting the full flow.
  10. Jan 28, 2023 at 4:31 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Cabin airflow on the 2nd gens sucks ass compared to many vehicles... even on high it is pretty weak. Nothing much you can do about it assuming your cabin filter is in good shape and the rest of your a/c system is in good order. If you live in a hot region this shortcoming is much more noticeable. The best thing you can do if you've covered all of the above is to get a good quality tint done to your truck.
    After reading your post again, despite its flaws you should still be able to tell a difference between all fan speeds, definitely sounds like something is wrong with your setup.
    davidstacoma likes this.
  11. Jan 28, 2023 at 4:45 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Yeah, pull the filter out & see if it improves. Mine works fine on all speeds.
    Try to keep it on recirculation, even when off. To keep the rodents out :)
  12. Jan 28, 2023 at 5:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The cover is above the blower
    If anything, leaving the cover open should increase flow to the blower.
    I’m not promoting this, I am just stating that should not cause the problem.
    I have found, that when it is set to Bidirectional (Floor / Dash) the speeds are harder to differentiate.
    Try setting it to dash only and see if you can tell a difference.
    If that doesn’t help, make sure it’s only coming from the vents selected.
    A very small amount or air maybe be felt from the others, but not a lot.
    You’ll know if they are working correctly once you feel.
    If all that doesn’t work, you might have a leak in the duct work.
    Not too long ago, mine spit out some of the foam that goes between the joint fittings.
    I never looked into it, mostly because I don’t want to crawl around on the floorboards or pull the dash.
  13. Jan 28, 2023 at 5:56 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Is this a recent change, and if so roughly when?
    I've had my 2010 for 10 years and no real change.
    How long ago did you do the cabin filter and roughly how old was it? Thinking out loud you might have had some crap that got out when you did it.
  14. Jan 28, 2023 at 10:12 PM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    x2 super weak, just pitiful…
