Cabin Air Filter Deletion?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Okkine 2.0, Oct 14, 2023.
  1. Oct 14, 2023 at 9:16 AM
    Okkine 2.0
    Okkine 2.0 [OP] Well-Known Member
    2022 TRD Sport, Lunar Rock
    I removed those annoying stickers on the sun visor.
    I drive with my windows open year-round, so the cabin air filter doesn't really do much of anything to keep the dust & pollutants out of the cab.
    Is the cabin air filter strictly for passenger comfort? Or is it needed to protect any components inside the heating & cooling system, such as the heater core, or evaporator?
  2. Oct 14, 2023 at 9:19 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It can help keep the evaporator core clean…
    Okkine 2.0[OP] and VB25 like this.
  3. Oct 14, 2023 at 9:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I thought the filter was after the Evap core?
  4. Oct 14, 2023 at 9:21 AM
    tcjacado
    tcjacado Well-Known Member
    I would not delete it.... I have seen air filters covered in leaves, rat/mice nests, dust, dirt and a quite a few other things in there. Stuff that you don't want in the system.
    Taco22trdor, szidls, b_r_o and 4 others like this.
  5. Oct 14, 2023 at 9:22 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Isn’t it in between the blower motor and core?
  6. Oct 14, 2023 at 9:23 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    When you say "delete", do you mean just remove the filter? If so that sure seems like a pointless thing to do? But hey, knock yourself out man!
  7. Oct 14, 2023 at 9:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :shrug:
    T-Rex266 and HondaGM[QUOTED] like this.
  8. Oct 14, 2023 at 9:25 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If the cabin filter helps to keep dust out of the cab, leave it in. Your instrument cluster will love you for it.
    wilcam47 likes this.
  9. Oct 14, 2023 at 9:26 AM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    It keeps dust and crap out of the blower wheel, core, evaporator and ducts. It’s more for the system than the driver. Just buy the K&N washable one if you are sick of replacing it a lot. Based on the amount of crap mine catches I would never delete it.
  10. Oct 14, 2023 at 9:27 AM
    Okkine 2.0
    Yes, just remove it completely.
    Why is it pointless? I drive with the windows open year-round, which means that the dust and pollutants are getting in the cab anyway.
    What seems pointless is wasting money on a cabin air filter that isn't keeping the dust & pollutants out of the cab.... which is exactly why I'm asking if it's needed to protect any other components such as the evaporator or the heater core.
  11. Oct 14, 2023 at 9:28 AM
    VB25
    2018 TRD OR ACLB AT
    If I recall, air is brought from behind windshield cowl directly through filter, then blower, then pushed through the core/evap/dampers and finally ducts.
    tcjacado and Okkine 2.0[OP] like this.
  12. Oct 14, 2023 at 9:28 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Well.. my bad ..actually it’s on the intake side of the blower motor.
  13. Oct 14, 2023 at 9:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought it was.
    HondaGM[QUOTED] likes this.
  14. Oct 14, 2023 at 9:30 AM
    Okkine 2.0
    As I said, I drive with the windows open year-round, so the dust gets in anyway.
    I'm more concerned with the heater core, and evaporator, so it entirely depends on whether the filter comes before or after those components.
  15. Oct 14, 2023 at 9:31 AM
    Buck Henry
    What the hell am i missing here? Then just don't buy any new filters!
  16. Oct 14, 2023 at 9:32 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Because this right here...just deal with it
  17. Oct 14, 2023 at 9:33 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    the filter helps keep the dust and dirt out of the blower motor and heater/AC coils
    if a $10/yr filter is to much wait until you have to take the dash out to fix the coils
  18. Oct 14, 2023 at 9:33 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Well.. before the Evaporator :fistbump:
    chris4x4[QUOTED] likes this.
  19. Oct 14, 2023 at 9:33 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    X3
    wilcam47[QUOTED] and tcjacado like this.
  20. Oct 14, 2023 at 9:34 AM
    Okkine 2.0
    That would lead to reduced airflow as the filter becomes clogged.
    HondaGM likes this.
