Cabin Air Filter, Engine Air Filter and A/C Blower Motor Kickplate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by asuchemist, Mar 31, 2014.
  1. Mar 31, 2014 at 6:15 PM
    asuchemist
    asuchemist [OP] My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Okay folks. I just changed my air filters cabin/engine.
    I noticed that the engine air filter only has to clips on the front side. Why no clips towards the rear? How do I know if the unit went back right?
    With the cabin air filter why isn't there a tray that the filter goes into? Also why do you install with the arrow pointing up? Isn't flow going down?
    On the passenger side where the A/C blower motor is, why isn't there some kind of kick plate?
    On both my Accords/CRV they both have kick plates, cabin air filter trays, and multiple snaps for fastening engine air filter setup.
  2. Mar 31, 2014 at 6:17 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The Toyota engineers wanted people to have something to talk about other than diesel and v8 engines.
  3. Mar 31, 2014 at 6:24 PM
    asuchemist
    NONE
    You are probably right. I also noticed the cabin air filter in the CRV almost 50% larger than the one I just pulled out of the Taco.
  4. Mar 31, 2014 at 11:34 PM
    Oggy
    Oggy Well-Known Member
    David
    Phoenix, Az
    2010 TRD Off Road
    The only issue I have that you pointed out was the kick plate, I don't know how many times after the fire academy when I am riding home in my steel toe boots I end up hitting the blower. That's one thing that has always bothered me but at the same time I know by making myself a plate to attach it will only take up more room.
    When it comes to the air filter in the engine bay just pull on the air filter housing and you will see right away when it isn't in.
  5. Mar 31, 2014 at 11:57 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    You can add a kick plate to the blower motor to make it easier to smack it when it starts to go. Personally, I use a tire bat.
    As for the air filter. There are tabs at the back that hook in when installed (think dovetail joints). And when you lock the two clips at the front, it is secure. If in doubt, grab the back of the filter box (inlet side) and see if it pulls off. If it does, you got it wrong. If it doesn't, you're good.
  6. Apr 1, 2014 at 4:20 PM
    asuchemist
    NONE
    Thanks guys. I thought maybe if I put it on wrong I would get a check engine light or something. Seems to be on tight. Had to get flashlight to see those tabs in back.
    Gonna do the LED in the hood mod to get some light. My garage lights are weak!
  7. Apr 1, 2014 at 4:27 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Leaks in the air filter housing (from improper installation) won't trigger a CEL, at least not right away. It just means dirty air can potentially get in through a seam and clog the 2ndary filter, which is not removable.
    The blower motor housing is pretty robust against the occasional kick. However, I wish Toyota could've designed the wire routing to be better protected.
    On the other hand, replacing the blower in the Taco is much easier than in the Accord, from what I tell watching the Honda/Acura repair videos on EricTheCarGuy.
  8. Apr 1, 2014 at 6:16 PM
    asuchemist
    NONE
    Do you recommend vacuuming the secondary filter every oil change or so?
    2008 CRV was not hard (space was cramped though). Pull off kick plate (clipped on). Unscrew three bolts. Unplug harness. Slap in new Motor.
    Taco does give you more room though.
  9. Apr 1, 2014 at 6:25 PM
    KenLyns
    Belly of the Beast
    ^If the primary filter is installed correctly, the 2ndary filter doesn't get dirty, so no.
    The 2ndary filter is intended to absorb any fuel vapors that manage to snake upstream through the intake, to satisfy the greenies in Calif. In the other 49 states, you can rip out the 2ndary filter without any ill effects, like I did. In 4-cyl Tacos, deleting the 2ndary filter is said to improve throttle response.
    You'll notice the Taco is missing a lot of little features common on other cars: no heated mirrors, no seat height adjustment, no tailgate lock, no keyhole on the passenger door handle... Toyota does it for cost-cutting, but also ends up with the lightest truck in its class.
  10. Apr 1, 2014 at 9:25 PM
    daniil
    daniil New Member
    nebraska
    2012 dbl cab trd sport
  11. Apr 1, 2014 at 9:53 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I'd have to double check mine, but I'm pretty sure the airflow is down, into the blower.
    The recirc door is just above the filter (switches to between the plenum intake and the foam block you can see above the filter).
    Thinking again, definitely down flow... one member found a mouse on top of his.
  12. Apr 2, 2014 at 7:00 PM
    KenLyns
    Belly of the Beast
    ^Yep, down-flow so the blower sees clean air. The owner's manual even warns of system damage if operated without a filter installed.
    Some filters have the arrows indicating flow direction, some have arrows indicating "this side up".
  13. Apr 2, 2014 at 7:21 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yet the '05 did not have one :confused:
  14. Apr 2, 2014 at 7:44 PM
    KenLyns
    Belly of the Beast
    May have taken Toyota/Delphi a year of high warranty claims to realize they need the filter. :laughing:
