Cabin Air Filter Replacement. Don't forget about it.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by w8n4mud, Feb 14, 2009.
  1. Feb 14, 2009 at 2:08 PM
    w8n4mud
    w8n4mud [OP] There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    Alright, 70K miles and I have never replaced my cabin air filter. I purchased my truck in Dec of 05'. So yeah it's been a while. Out of sight, out of mind. I saw a thread about where the cabin air filter could be found and sure enough it needed replacing asap. I went to Toyota. The guy at the parts counter said there were no aftermarket filters available. The going price was over $32. So I checked online. I found this and purchased it for less than $13 shipped! Be aware and be advised... check out the filter.
  2. Feb 14, 2009 at 2:27 PM
    stephbm6
    stephbm6 Well-Known Member
    West Jordan, Utah
    2006 TRD Double Cab
    DAMN!!!!!!! :eek: that is some dirty shit. I have to replace mine too, thanks for the reminder.
  3. Feb 14, 2009 at 2:28 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Wow, that is one dirty filter. Great find for a low cost air filter.
  4. Feb 14, 2009 at 2:45 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Jeez that is dirty! Glad you got a new one to replace it with! I heard you can use furnuce filters as well by cutting them into 4ths or something like that.:rolleyes:
  5. Feb 14, 2009 at 3:24 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    WW really? if so im going to change mine right now
  6. Feb 14, 2009 at 3:44 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah it's under the cheap mods section on here.;)
  7. Feb 14, 2009 at 4:32 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    These are the guys I bought it from on eBay.
    TNA AUTO PARTS
    10160 Rush St.
    El Monte, CA
    91733
    The sad thing was is that when I found the air filter it was dirtier. I vacuumed it and brushed off as much dirt as possible.
  8. Feb 14, 2009 at 4:35 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Damn man thats a dirty ass airfilter after the ocotillo run i changed my filter out i go to toyota san diego $20 there so i but them although i know i can find it cheaper.
  9. Feb 14, 2009 at 4:54 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    If it looks that bad at 70,000, mine must look awful. Mine has never been changed and it has 217,000. How much difference does it make if you change your cabin filter anyway?
  10. Feb 14, 2009 at 5:06 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    BobWilson Did your year truck even come equipped with the cabin air filter?
  11. Feb 14, 2009 at 6:07 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    :der::crazy::der: Yeah that's a good point! Well BobWilson? LOL. Well, in any event, I'm seriously glad I changed it. BTW, if you haven't looked up the tread to find where the Cabin Air Filter is even located, check behind your glove compartment. Good Luck and be careful with that little pump that helps support the glove box door.
  12. Feb 14, 2009 at 6:17 PM
    Lentsnh
    Oh ok I must have skipped over it then:rolleyes:
  13. Feb 14, 2009 at 9:06 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I just checked mine last year and it was pretty bad - and it only had 12,000miles on it at the time. I bought another one and installed it. Cleaned the dirty one and have it ready to swap out probably sometime this summer.
  14. Feb 14, 2009 at 9:47 PM
    Taco93
    Taco93 Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
  15. Feb 15, 2009 at 6:55 PM
    orangebutte
    orangebutte Well-Known Member
    Tucson, AZ
    08 access cab 4x4 trd off road w/lock diff
    Speaking of the glove box pump - how the hell do you reinstall it?. I've tried and failed so I've given up at this point. Glove box still functions fine.
    I'm sure it's affecting my trucks center of gravity or some other important thing. Any hints?
  16. Feb 16, 2009 at 6:58 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    That's funny. Do it with a flashlight or in direct sunlight. Attached to the pump on the back side are two holes. Use the lower one (the one that affects your center of gravity) and insert into it the little black clips (two of the side by side) that extend outward. You'll notice that at the end of the clips are edged that would hold it in. It's a little tricky.
  17. Mar 8, 2009 at 9:21 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    I had the same problem today when I installed my cabin air filter. I couldn't figure out how to reinstall that little glove box pump. I tried using the lower hole and it still wouldn't stay. Can you take a picture of how the glove box looks installed please?
  18. Mar 8, 2009 at 10:20 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    Hope this helps. There's another one coming in just a sec.
  19. Mar 8, 2009 at 10:26 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    One more on the way.
  20. Mar 8, 2009 at 10:40 PM
    w8n4mud
    Albert
    San Diego, CA
    2015 Subaru WRX
    Last of the pics. I didn't make the quality smaller. Sorry for the different posts. Hope it helps man. At least you got the Cabin Air Filter replaced!
