Cabin Air Filter
Discussion in 'Technical Chat' started by Steve Renolds, Dec 27, 2006.
  1. Dec 27, 2006 at 10:46 AM
    Steve Renolds
    Steve Renolds [OP] New Member
    In the manual it states that the "Cabin Air Filter" should be changed in my '06 Tacoma at regular intervals (every oil change). Elsewhere in the manual it states that changing the cabin air filter can be done by the customer (i.e. I don't have to pay the kid (sorry, I should have stated "the factory trained Toyota technician") to do something I can do myself.
    But... nowhere in the manual does it state just where this cabin air filter is located. Is there a cabin air filter for an '06 Tacoma - and if there is, just where is it to be found?? :confused:
  2. Dec 27, 2006 at 7:42 PM
    jskicet
    jskicet Member
    behind the glove box, just remove it (the box)and you'll see t
  3. Dec 27, 2006 at 11:11 PM
    armsraised
    armsraised Member
    good to know
  4. Dec 28, 2006 at 7:36 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I don't think that's necessarily a cabin air filter, but it's a filter for the AC. According to my dealer, the AC filter just protects the AC system, and a Cabin Air Filter keeps dust/allergen's and pollutants from the entering the cab. Makes sense since my Tacoma's interior gets rather dusty, and I don't drive with the windows down or anything.
  5. Dec 29, 2006 at 6:22 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Hey Steve check into that every oil change thing, I was told every 20,000 miles or 24 months,
    Also you might not need to remove the glove box, some of them you push the one side in (stop) and the box drops down on an angle. Then you can see the cover (one clip on both sides) take it off and pull the old filter out.
  6. Dec 30, 2007 at 5:24 AM
    danusa
    danusa Well-Known Member
    My `06 Manual tells you about it.
    I have no plan to change it anytime soon.
    I am not in a dirty enviorment.
  7. Dec 30, 2007 at 6:06 AM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    all air coming into the hvac duct goes through the cabin air filter..it does not protect the AC system it is only there to help filter the air going into the cabin. Pop the little door damper off the plastic nipple on the right of the box and pull down the box and there is a tray behind the box..If you put a dryer sheet down first the whole truck smells like clean laundry!!!!
  8. Dec 30, 2007 at 7:14 AM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Oh boy I' m going to wrap mine in Bacon, hey Master can you help me out with this one ? :laugh:
    Philrab likes this.
  9. Dec 30, 2007 at 7:27 AM
    kngharley
    kngharley Well-Known Member
    Corona, Ca
    I think in the manual it does say every 20k but I pulled mine out at 4000 and there were small leaves and dust in it already. I like the idea of a drier sheet. Have to try that one!!!!
  10. Dec 30, 2007 at 7:45 AM
    danusa
    And why would you want a truck to smell like laundry?
    Trucks smell of cigars, beer and dirty laundry. Worn by occupants.
    Bono likes this.
  11. Dec 30, 2007 at 9:10 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i already changed mine out at 25k miles. it was getting dirty around 20k. i bought one shipped off ebay for like $12, whereas the dealers wants $35. all there is to it is popping the glovebox down, and there's a lil flap that snaps down about midway of the large black box straight in front of you. its just a thin, white filter. its supposed to be a "HEPA" filter and clean the air going into the cabin. if you look up "tacoma cabin filter" you should be able to get one for cheap, if you do wanna replace it.
  12. Dec 30, 2007 at 4:03 PM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    Or you can just remove the filter every few months and blow it out with compressed air. Saves money.
    If you're really inventive, you can go to your local upholstery shop and get some leather scraps. From there you cut the leather into 1/4 inch wide strips and lay them inside the folds of the filter. When the air passes through it, your truck smells like a new vehicle.
  13. Dec 30, 2007 at 4:11 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Had to change mine at 15000 miles due to the fires here in san diego and i would say just check it on your own once in a while i found some crap like rat shit in mine leaves so just check it when you can,heres a website where you can find the airfilter for cheap www.allergybegone.com/
  14. Dec 30, 2007 at 4:25 PM
    danusa
    My manual says that recirculate works on AC and heat.
  15. Dec 30, 2007 at 4:32 PM
    danusa
    Only a CFII could come up with that.
    See you at Oshkosh. Perhaps we can do some "FAA Unusual" manouvers.
    Let`s see, inverted means push instead of pull.
  16. Dec 30, 2007 at 4:34 PM
    TSUNAMI*22
    Stockton, CA
    I wish I could go to Oshkosh.
    BTW, I'm not a CFII, Just a CFI. ;)
  17. Dec 30, 2007 at 4:43 PM
    danusa
    As my buddy Rod Machado would say; you are operating below your potential.
  18. Dec 30, 2007 at 4:50 PM
    TSUNAMI*22
    Stockton, CA
    The story of my life.
    Funny thing is that I'm interested in what you changed in your edit. :rolleyes:
  19. Aug 12, 2008 at 7:38 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Wow, checked mine today for the heck of it.... My truck is 1.5 years old with 10K miles on it.
    That thing was DIRTY!! Holy crap!!
    I had a new one in the garage from when I swapped it from another one that I had (and didn't need) for another vehicle. So I slapped the new one in and I'm gonna take this dirty one to work and blow it out with an air hose and see how durable this thing is. I might even run some water/soap through it and allow it to dry till next year when I can pop it in again. I'll have two that I can rotate year to year.
    Here's some thread about people cleaning them.
    http://www.toyotanation.com/forum/showthread.php?p=2442937#post2442937
    Someone (like AFE) should start making washable cabin air filters. I'd buy one.
  20. Nov 7, 2008 at 2:26 PM
    jtaco
    jtaco Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    my glove box doesnt come down far enough, i did it on an 05 before, but my new 07 will not come down far enough for me to get to it. what else do i have to undoo?
