Cabin and Engine air Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JohnWJ, Sep 10, 2022.
  1. Sep 12, 2022 at 11:45 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Engine: OEM.
    Cabin: whatever is on sale and fits.
    As others have mentioned, steer clear of K&N. Marginal benefit for drastically reduced filtering capability, or in other words, negligible performance increase while letting a bunch more dirt, sand, debris, etc. into you engine.
    The point about the filter oil affecting MAF readings that others have made is valid too.
    I'm going to have to try that one...
    O'DubhGhaill likes this.
  2. Sep 13, 2022 at 2:38 PM
    TheArea51Rider
    TheArea51Rider Member
    What he said - I couldn't figure out why there was fine dust on "engine side" of my K&N filter. A little reading, and it went straight into the garbage. NAPA Gold forever now.
  3. Apr 19, 2023 at 8:42 AM
    smikski
    smikski Well-Known Member
    2016 4x4 2.7 - 3 pedals
    skid plates , leer cap , thule roof rack , tires 1 size up
    Seems to happen OFTEN , any body find a cure , I put moth balls under truck and hood
  4. Apr 19, 2023 at 8:52 AM
    lynyrd3
    Bill
    East Central Upstate NY
    AFE dry for engine and Amazon something or other for the cabin . It’s like $7 for cabin filter . I change mine twice a year .
  5. Apr 19, 2023 at 8:57 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    smikski[QUOTED] likes this.
  6. Apr 19, 2023 at 9:31 AM
    Dane
    Dane Well-Known Member
    Dane
    Houston, TX
    07 PreRunner SR5 TRD Off Road
    I am using Denso with no problem at all. Denso is making OEM toyota filters and other parts just priced lower.
    I have spare Denso filters for engine and cabin right now in my garage. I was ordering some other parts from rockauto and to save on shipping I just got filters as well.
    Using denso for Honda CRV as well.
  7. Apr 19, 2023 at 11:37 AM
    jameswirl
    jameswirl Well-Known Member
    Denver, CO
    2010 Pyrite Mica DCLB TRD Sport
    I use the Toyota OEM for both. I’ve had good luck cleaning up the cabin air filters and getting 3-4 uses out of them. I change/clean the cabin air filter with every oil change . (5k interval) I use compressed air to blow them out, soak and scrub with a little Woolite and a brush that gets down into the pleats and then air dry. The filter paper is very durable.
  8. Apr 19, 2023 at 12:01 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I don’t think it makes any damn difference what engine air filter or what cabin filter you use. Especially the cabin filter. Buy the cheapest you can find and change it when needed. It makes no difference for the engine air filter either. Any evidence an engine has failed due to the brand of air filter (as long as it is changed per manufacturer recommendation)? If some filters (fram always gets bad mouthed) are so bad there would be hundreds or thousands of examples of engine malfunction or failure due to filter . I’ve had several dozen vehicles in my life, I’ve always maintained them to the max, not one problem due to the brand of filter. The key is to change what ever filter you use regularly. If it makes you feel good that you pay big bucks for some brand filter, then by all means go for it.
    O'DubhGhaill and clifpaul like this.
  9. Apr 19, 2023 at 12:20 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I put a K&N Cabin Filter in mine, clean it twice a year and stick it back in.
    SWPA Tacoma likes this.
  10. Apr 19, 2023 at 12:26 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Ditto this. My first cabin filters *might have been* OEM, but who remembers stuff like that nearly 18 years later?
  11. Apr 24, 2023 at 5:02 PM
    iiggii
    iiggii Well-Known Member
    jeff
    2010 tacoma access
    lift n radio
    OEM
  12. May 17, 2024 at 5:26 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yank mine out blow it out with compressed air put it back in. Engine air filter have a look if it's clean put it back in used 2 in 155K.
  13. May 17, 2024 at 6:25 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    This. OEM cabin every Spring and Fall. OEM air every 30k with a MAF spray and throttle body clean with new OEM o-ring. Good to go.
