Cabin fan, not much air blows in
Discussion in '5 Lug' started by Mytacomadream, Sep 30, 2020.
  1. Sep 30, 2020 at 2:16 PM
    Mytacomadream
    Mytacomadream [OP] New Member
    Rudy
    1998 tacoma sr5
    Hey guys, I'm new here cause I just got my truck. I have a 1998 tacoma Sr5 , 4cyl automatic.
    My problem is I'm getting very little air into the cabin. The ac is cold, heater is hot. You can feel it in the dash. Just the air is not pushing it out. I can hear the fan blowing. Need help
    Thanks in advance.
  2. Oct 6, 2020 at 10:24 AM
    bretts
    bretts Well-Known Member
    Pasadena, TX
    98 Tacoma Regular Cab 2WD
    your cowl/venting might be getting clogged up or the blower motor may be failing. there is no cabin air filter on that year model
    HarborSeal and Mytacomadream[OP] like this.
  3. Nov 4, 2020 at 6:41 PM
    Mytacomadream
    Rudy
    1998 tacoma sr5
    The fan works. Its the air coming in. Its not enough. I think coming is blocking the fan from outside in, if that makes sense
  4. Nov 4, 2020 at 6:43 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    If something was blocking it from the outside, your truck would essentially just be running as if you had the recirculation button activated. Is the fan working at all speeds?
  5. Jan 1, 2021 at 10:30 PM
    Tacoma Nick
    Tacoma Nick Active Member
    Nick
    Michigan
    2008 Indigo Ink Pearl Regular Cab 2TR auto 2WD
    All new under the floor, factory frame swap. Bucket seat swap. Bilstein 4600 shocks and X Runner rear swaybar. 4:10 DIfferential. 225/60/17 on Sienna 5 spoke alloy wheels. After market black headlights. OE replica fog lights. OE Intermittent wipers plug and play. Leather steering wheel (OE eBay) that came with a cruise stalk, I bought the $38 OE wire to plug into the clock spring, plug and play.
    If it has a Cabin air filter, change it. It will make a difference, because it's clogged with debris and dirt. Worked for me.
  6. Jan 4, 2021 at 5:20 PM
    HarborSeal
    HarborSeal Well-Known Member
    96 taco, 84 4 runner
    lce headers, ome suspension,
    the blower fan is under the passenger side dash. I bet the plastic tubbing just fell off. take an hour or so and pull the dash and make sure all the tubes are connected.
