Cabin Filter-Cheap replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WV_Tacoma, Oct 13, 2011.
  1. Oct 13, 2011 at 11:29 AM
    WV_Tacoma
    WV_Tacoma [OP] Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Cheap Cheap Cabin filter replacement.
    Open Glove box, push in sides and drop further down to access the rectangle box door above the fan housing.
    I was using a home filter like Filtrite, 20"x25"x 1" thick, it is more ridged (however not better), cut to fit 8.5" and then make cardboard edges all around, pretty much like stock. It was fair but much more time consuming and a bit more expensive. I think this new mod below is faster, much better and simpler.
    Removed my cabin filter aprx 6 mnths old, it was covered with leaves & dirt. Went to wall-mart and finally found a replacement 20$ (CF10374 Fram freshbreeze), the fit isn't exactly perfect air tight and isn't intended to be.
    So I went to the home AC filter section and found what looked to be a good replacement idea and much much cheaper. The Purity home air filter is 20"x25", has a wire type frame that can be cut to fit, then cut the filter material to fit.
    I cut the frame out on the corner and made it 8.75" wide slightly wider then stock 8.5", this way it slides in and curves downward on the fan housing above the blade. Then cut the filter material out same.
    You can get 5 replacements out of the filter by cutting to size and then there is two smaller pieces left over that I just stapled overlapping to make the correct size. Works Great, I have good coverage on all sides, maybe better then stock due to slightly over sizing the soft material(makes snuger fit). I inspected all around inside with a good quality light and see no problems. Plenty of fan clearance.
    Cost is $10 but you get 5 uses from this filter. The plastic frame that U cut out on the 1st piece is last time you have to do this, as it will stay and the filters will just slide in and out.
    After installing the glove box back, I had to place the little damper on the box gently into place and then used small screws to keep the little mouths open on the damper holders. they get squeezed down and want hold the damper after you close it a couple of times, so place it on, then screw small screws into the ends, just enough to spread the opened back and just enough screw to hold till next time.
  2. Oct 13, 2011 at 3:36 PM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    :eek: But ... but ... it's not OEM! It's not as good!
    I'll buy you a virtual beer out of the first $20 I save :)
  3. Oct 13, 2011 at 3:38 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    You can buy cabin filters online for about $4 each. I think they were $3.68 when I bought half a dozen a few months ago.
  4. Oct 13, 2011 at 3:38 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
  5. Oct 13, 2011 at 4:20 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    But what about the satisfaction you did it yourself!!! and the hours wasted doing it....:(....
    But I think this beats the OEM fit. Not that it really matters that much. Hell your in a truck..
    Where online did you say? I would still stay with mine, I am very picky and this suits me.
  6. Oct 13, 2011 at 4:31 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  7. Oct 13, 2011 at 4:58 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  8. Oct 13, 2011 at 5:10 PM
    08pretaco
    az
    That's why you buy 10, shipping OS almost the same as 10 or 1
  9. Oct 13, 2011 at 5:23 PM
    horwitzs
    Seth
    Dayton, WA
    TX Pro
    This^^
  10. Oct 13, 2011 at 5:23 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Great idea OP...Thanks for sharing!!:thumbsup:
  11. Oct 13, 2011 at 5:43 PM
    08pretaco
    az
    Before you buy, hit up some local buddies that want some, get a lump sum to order, disperse and collect
  12. Oct 13, 2011 at 5:46 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
  13. Oct 13, 2011 at 6:12 PM
    WV_Tacoma
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    Wow 3-4$ for the Lazy mans filter isn't bad at all.
    Wally'sworld wanted darn near 20$ for their Fabreeze version. Thought I was on to something.....
    I still stand behind mine being a slightly better fit.
  14. Nov 15, 2011 at 1:01 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
