Cabin Fuse Box - 7.5A Tail for powering BD S8 Backlight
Discussion in 'Technical Chat' started by in2seconds, Mar 3, 2023.
  1. Mar 3, 2023 at 1:17 PM
    in2seconds
    in2seconds [OP] Well-Known Member
    Edmonton, AB
    2021 TRD Offroad Premium
    Hello - wondering if anyone has insight or experience in doing what I have in mind:
    I have a BD S8 40" (white) that is connected to a dual switch (white / amber) that controls the amber backlight and white light. I plan on getting another BD S8 30" (amber) with the intent of using the same switch to control the amber light. I then plat to use a fuse tap for the amber backlights for both light bars, and tap them into the tail light. Note I plan on using the 64-0122 harness which has four wires:
    Red connects to the 12V source
    Black connects to the ground
    Green is for the amber backlights
    Yellow is for the relay
    Question:
    1. Is the 7.5A tail light fuse always hot or switched? I'm hoping for a tap that only goes on with the headlamps / parking lights and ideally within the cabin fuse box.
    2. Would this wiring diagram work on the switch side:
    Dual switch has five wires:
    Black for ground; connect to black wire (from the two light bars)
    Red for battery; connect to red wire (from the two light bars)
    Blue for relay 1 (upper /amber switch); connect to S8 30" (amber) yellow wire
    Green for relay 2 (lower / white switch); connect to S8 40" (white) yellow wire
    Yellow for switch backlight power; connect an add-a-fuse
    The green wires for both light bars will be connected to an add-a-fuse and ideally tapped into the tail light fuse.
    Note while a switch controller would work better, I don't plan on installing one right now. I also don't have any spare OEM blank slots for more switches. I do want a reversible solution.
    Would this work / make sense, and if it doesn't, what's a good alternative?
