Cabin Fuse Box - 7.5A Tail for powering BD S8 Backlight
Discussion in '3rd Gen. Tacomas (2016-2023)' started by in2seconds, Mar 3, 2023.
  1. Mar 26, 2023 at 5:03 PM
    in2seconds
    in2seconds [OP] Well-Known Member
    Edmonton, AB
    2021 TRD Offroad Premium
    I did not use a jumper wire but I tried testing by hooking the (amber) red wire to the green switch wire. Same result, both lights turned on.
    I also tried the previous configuration of the (green) backlight wire to the blue switch wire and that did not work either, so that’s why I ruled the switch to be faulty.
  2. Mar 26, 2023 at 5:16 PM
    caribe makaira
    Caribbean, Puerto Rico
    Since you suspect that the switch is bad, you could open it up to view the board for brown/black/burnt evidence...
  3. Mar 26, 2023 at 5:29 PM
    caribe makaira
  4. Mar 26, 2023 at 5:41 PM
    caribe makaira
    You should get a different switch than the one you have. One that selects White OR Amber (like the original switch), that way you prevent sending juice to both white and amber at same time.
  5. Mar 26, 2023 at 5:50 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    “I wired the new configuration based on this:
    coupled 12V black ground —> black ground switch”
    Keep the switch dimmer circuit completely separate from your light bar harness, especially the grounds. The dimmer circuit is not the same ground. That means don’t connect the black switch wire to any other wires if you connect it to the green dash illumination wire. You could lend up with positive voltage on both sides of a relay coil rendering it inoperative, or short out the illumination circuit if you also connected them to the chassis.
  6. Mar 26, 2023 at 5:51 PM
    in2seconds
    Edmonton, AB
    I’ll look at this option instead. Since it’s unlikely I would have both bars on at the same time.
  7. Mar 26, 2023 at 5:52 PM
    caribe makaira
    WTF?
  8. Mar 26, 2023 at 5:56 PM
    caribe makaira
    The LED bars have 2 relays each?
  9. Mar 26, 2023 at 5:59 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Think about it, he says he connected the blacks together. If it’s also connected to the green jumper wire that puts a positive voltage there. If he doesn’t and connects to nothing else it’s not grounded. If he does and also grounds to the chassis it’s a dead short of the green wire in the illumination circuit.
  10. Mar 26, 2023 at 6:02 PM
    in2seconds
    Edmonton, AB
    Well, 1 relay for each led bar harness.
  11. Mar 26, 2023 at 6:05 PM
    caribe makaira
    If he has, then yes. He does it correctly then the don't place the switch ground to the vehicle illumination is an incorrect statemant:
  12. Mar 26, 2023 at 6:06 PM
    caribe makaira
    Aw shit, how does one relay change the amber to white on your TACO, or do you have the amber on a separate circuit?
  13. Mar 26, 2023 at 6:09 PM
    in2seconds
    Edmonton, AB
    I am not sure, but again I suspect the actuation of the white switch also switches on the amber relay.
    Technically the amber is on the same circuit, as it’s coupled on both the ground and 12V source.
  14. Mar 26, 2023 at 6:11 PM
    caribe makaira
    :facepalm:
    Do you have the DD site link to the Bars you have? Or have clear picture of the relay wires to the bars?
    bagleboy likes this.
  15. Mar 26, 2023 at 6:14 PM
    #35
    bagleboy
    Scott
    Norcal, Santa Rosa
    Obviously. What I said was don’t connect the illumination ground into the relay ground. It’s for the switch alone and nothing else.
  16. Mar 26, 2023 at 6:18 PM
    #36
    in2seconds
    Edmonton, AB
  17. Mar 26, 2023 at 6:34 PM
    #37
    bagleboy
    Scott
    Norcal, Santa Rosa
    Harness linked shows separate switch for backlight feature.
  18. Mar 26, 2023 at 6:40 PM
    #38
    caribe makaira
    It does, but there's no info on if white color has priority over amber.
    As in:
    • Vehicle OFF, all OFF
    • Vehicle ON, Both switches left ON, White illuminates only.
    • Vehicle On, Amber selected, then white is selected and amber is off, even with amber switch on.
    • etc...
  19. Mar 26, 2023 at 6:41 PM
    #39
    in2seconds
    Edmonton, AB
    Backlight is wired independently at the moment, tapped to tail fuse and works as intended.
  20. Mar 26, 2023 at 6:42 PM
    #40
    caribe makaira
    Does it turn OFF if you select white LED's? The amber switch looks high amp type, not 3 amp max type. (like the Dual China switch giving you issues)
