Cabin nosie
Discussion in '2nd Gen. Tacomas (2005-2015)' started by softplastic19, May 15, 2017.
  1. May 15, 2017 at 8:29 AM
    softplastic19
    softplastic19 [OP] Member
    2012 v6 SR5 PreRunner TSS Sport Series
    When starting my truck, it sounds like the engine is right in the passenger seat and then at HWY speeds, the wind noise is terrible coming from the passenger side. Anyone else have this issue? I can literally hear the gravel scraping on the concrete as if all my windows were down when turning in and out of parking lots at low speeds.
    ChadsPride likes this.
  2. May 15, 2017 at 8:56 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    There's gotta be a seal missing somewhere. Have you checked the weatherstripping around all your doors? Seals around the windows? Do you get water in the truck when it rains or when you wash it?
  3. May 15, 2017 at 9:48 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    When you start your truck, does the sound you hear get quieter after 10-15 seconds? On the '12's the air pump will run on start up and it is loud enough to hear in the cab. For wind noise, check the door seals. Close the door on a thin piece of paper and verify it has a lot of drag to pull it out (or rip).
  4. May 15, 2017 at 9:55 AM
    softplastic19
    I haven't noticed it getting quieter after I start it. I can definitely go check though. It's just the initial crank of the engine I hear and then the loud wind noise at HWY speed. All the seals to me look good and not dry rotted and no water gets in my truck when it rains or I wash it. I will go and do the paper test like you suggested. On a side note, I did have a K&N air filter in for about 6 months, decided to replace it with a stock one, and about 5 days after I did this, the noise started. Any chance this is related?
  5. May 15, 2017 at 9:57 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    If it happened after changing the filter, pop the hood and make sure the intake hoses are all still connected.
    Sidney Vicious and ChadsPride like this.
  6. May 15, 2017 at 9:57 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I wouldn't think the filter would be related, but check it to ensure nothing has been sucked up into the intake.
  7. May 15, 2017 at 10:04 AM
    softplastic19
    All the hoses are good and the paper does slide out relatively easy, but it is tight when pulling it through.
  8. May 15, 2017 at 12:14 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Missing cabin air filter??
