Cabin Pressure vent leaking water
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, May 4, 2024.
  1. May 4, 2024 at 11:49 AM
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Been dealing with a water issue on my access cab. I thought it was the third brake light. Replaced that and still have water leaking. WTF.
    So I pull off the panel covering the wall and notice the cabin pressure vent and see water all around it. This is the
    Am I right to assume I have to take the entire bed off to replace that gasket?
  2. May 4, 2024 at 1:13 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I'm here for the outcome, I tried to remove mine and it SEEMED as though the bed had to come off , I may be wrong tho actually I hope I'm wrong
  3. May 5, 2024 at 3:18 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Looks like you don't really have to remove it completely. You can slide it back enough to get to the valve. Hopefully the bed bolts come out. Already had the rear ones out.
    Still these gaskets pisd me off. Literally both the third brake light and the cpv at the same time. The gaskets are just foam. No wonder they just rot off.
  4. May 9, 2024 at 8:56 AM
    Jankie6
    Jankie6 New Member
    Jean
    2016 Tacoma TRD Sport 4x2
    Have the same problem in my 2016. Looking on ways to resolve before pulling tha back out.
  5. May 14, 2024 at 8:08 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I was gonna try and use some RTV sealant from the inside, but just can't see it sealing good.
    Taking the bed off to get access to it and seal it is the only way I can see to make it seal properly.
    One trick to save you some time, is to use a wedge on the top. A paint stick should work, to hold the top firm. It works perfect for me. Has kept water out for three rains now. So until I have time to pull the bed back that is what I have been doing.
    As for my bed, I already checked all my bolts, they all came loose with a little elbow grease, Thank God!
  6. May 14, 2024 at 8:11 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I still can't believe more people haven't had this issue. Both my third brake light and cabin pressure gasket failed at exactly that same time. Such a stupid design on Toyota's part. Especially that cabin pressure value. Could have just bolted the thing on or a bunch of other designs.
  7. May 14, 2024 at 5:41 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    Interesting. I've owned the truck for 14 years and didn't know there were vents back there.
  8. May 15, 2024 at 6:14 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I wish I never found out. It's a PITA
    inwood customs likes this.
  9. May 19, 2024 at 11:37 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Those bed bolts are a bitch to get out. I got one left. Had to cut out one.
  10. May 19, 2024 at 1:37 PM
    inwood customs
    Dave
    Committed to this, I like
  11. May 19, 2024 at 1:58 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Fairly common design amount truck makers. You will need to slide the bed backwards a few inches to remove the vents.
  12. May 24, 2024 at 3:16 PM
    Jankie6
    Jankie6 New Member
    Jean
    Im trying today sliding the bed. Ill post later for an update.
  13. Jan 2, 2025 at 1:38 PM
    kmoneyy
    kmoneyy New Member
    Did you find a fix for this? Just discovered this issue in my 2018. They are leaking a ton of water into the interior everytime it rains.
