Cable Chains and 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mwinni, Oct 28, 2013.
  1. Oct 28, 2013 at 1:49 PM
    mwinni
    mwinni [OP] New Member
    mark
    Colorado
    2016 DCSB Sport 4x4 Automatic
    I have a 2013 Tacoma Double Cab 4wd Sport Package with Tow Package - I added an ARE cap.
    This is my first truck. I've driven Jeeps for over 20 years. I'm lovin the Tacoma and will probably never go back to the Jeep. I'm traveling from Colorado to Oregon in late December. This is probalby a stupid question but when I put the cable chains on the rear tires do I then drive in the 4wd setting or 2wd setting? I will be going through three pretty tricky mountain passes where they can measure snow in feet and not inches. Some require chains. I've made the trip many times, but never in the heavy snow months. I appreciate all comments. Thanks, Mark
  2. Oct 28, 2013 at 1:51 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Why not chains front and rear and 4WD?
  3. Oct 28, 2013 at 1:52 PM
    mwinni
    mark
    Colorado
    Owner's manual says rear only due to clearance.
  4. Oct 28, 2013 at 2:07 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Slap the chains on the rear in 4WD, you'll be fine. Smart move to get the chains, a lot of people don't do it. Hell, a 2WD with chains can get to some really nasty places.
    I think chains on the front wheels would be OK for clearance, never tried it though.
  5. Oct 28, 2013 at 2:48 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
  6. Oct 28, 2013 at 3:09 PM
    Cold Iron
    Cold Iron Well-Known Member
    Mn.
    2013 AC T|X Baja
    I like and have had good luck with Rud Grip chains in the past but have only had my Tacoma for a month, I just started looking at chains for it. If you put chains on only the front your rear end can slide around on you, it pulls and steers better with them on the front IME however. Any time I put on chains I am in 4WD and it isn't just snow, on slick clay in NC Co. while mulie hunting chains will get you through some pretty hairy places. If I am going through the trouble of putting on chains I prefer them front and back. With the lift in the front of the T|X Baja not sure if chains will clear or not have a feeling they may. I am more concerned with damage to the fake beadlocks right now. I just heard back from a RUD dealer today and they no longer sell the alloy wheel protectors (AR Rim Protect). So not sure which ones I will end up with. It is worth spending the extra money to get easy on chains. The less time you have to spend putting them on the better! Not willing to go $500+ a pair for the Thule easy on and quick release however.
  7. Oct 28, 2013 at 5:33 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I tried to put cable chains on the front of mine. There is not sufficient clearance. That is a major design issue IMO.
  8. Oct 28, 2013 at 7:50 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Chains on the rear. Here is mine
  9. Oct 28, 2013 at 7:55 PM
    mandzach
    mandzach Well-Known Member
    Not to hijack but what is a good brand of chains and where do you guys buy them at?
  10. Oct 28, 2013 at 7:57 PM
    sandjunkie
    Aaron
    OC
    SCC Z chain. Bought them at 4 wheel parts.
  11. Oct 28, 2013 at 8:11 PM
    2011TRDSPORT
    2011TRDSPORT Well-Known Member
    Len or Lenny
    Kamloops, BC, Canada
    Tacoma TRD Sport. Magnetic Gray
    2" front and rear.
    My 2011 does NOT have enough clearance for chains or cables on the front axle. I couldn't believe it! I then looked looked in the manual and it clearly says not to install them on the front wheels. Check your manual to see if your 2013 says the same thing. Unless you have aftermarket wheels with an offset, I wouldn't even try it. You could cause some serious damage! This is a big design flaw by Toyota...
  12. Oct 29, 2013 at 4:46 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Note to... everyone. As stated before chains will not clear on the front, even if you have different backspacing on your wheels. Dont even try it. Not worth it.
  13. Oct 29, 2013 at 5:00 AM
    Boone
    Boone, NC
    Airbags deployed
    Had chains F&R on mine.:notsure:
  14. Oct 29, 2013 at 5:15 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    That is a good brand of chain. I have used them in the past.
    I bought a set of These last year for my PreRunner when I had it and never had any trouble in the snow. It snowed every day in Colorado back in March and we went from Colorado Springs to Durango without any issues.
  15. Oct 29, 2013 at 5:24 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Many moons ago we used cable chains on the front of my wife's Honda Prelude. It was a bad winter and they were on for several days at a time. The cables ruined the sidewalls of her tires from the rollers spinning on the cables. Are the cable chains made now so they don't eat the sidewalls of tires?
  16. Oct 29, 2013 at 5:29 AM
    memario1214
    Colton
    Missoula, MT
    Brand of chains/wheel specs? I've yet to get a set to fit any Tacoma 2nd Gen
  17. Oct 29, 2013 at 5:56 AM
    MajKong
    MajKong Well-Known Member
    Johnny
    Reno, NV
    2008 4X4 Access Cab 4cyl
    Seatbelt Buzzer turned off, Bed Mat, Illuminated 4X4 switch, Intermittent Wipers, Fumoto drain valve, LCE header, fog lights
    Geez. I bought 4-wheel drive so I wouldn't have to chain up anymore.
  18. Oct 29, 2013 at 6:15 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    What kind?
    Looked at the link above and saw some meet S.A.E. Class "S" clearance requirements. Does that mean that they will fit the taco front?
  19. Oct 29, 2013 at 6:15 AM
    Boone
    Boone, NC
    Airbags deployed
    iirc they are Peerless V chains. Been a few years, but I'm pretty sure they are sized for 33 12.5's. A little loose on my KM2's but not horrible. Only used them once, but didn't have any clearance issues.
  20. Oct 29, 2013 at 6:32 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    There's only like 1/2" clearance between tire and UCA on my 2013 taco. No way a chain could fit in there. Maybe if you were using a 1 1/2" to 2" spacer on your wheels, then you could fit chains on the front. The rear has enough clearance, but you better have you're chains on tight, because if they're loose at all, they could possibly rip off fender flares and/or mudflaps.
