Cable for the spare snapped
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Jan 6, 2022.
  1. Jan 6, 2022 at 7:44 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    So is this why toyota switched from cable to chain for the spare tire? My cable for the spare snapped and I didn't even know.
    Is this common can someone relate and how can I fix this. I lost the spare and I didn't even know it fell off.. it frayed on thr end of the cable. Is it fixable????
  2. Jan 6, 2022 at 7:56 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
  3. Jan 6, 2022 at 7:58 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    pinktaco808[OP] likes this.
  4. Jan 6, 2022 at 12:43 PM
    pinktaco808
    Pretty sure corroded and going over bumps everyday it a daily and beach truck. It. 06
  5. Jan 6, 2022 at 12:49 PM
    pinktaco808
  6. Jan 6, 2022 at 12:49 PM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    Cables commonly rust from lack of use so you can't drop the spare when you need it. You can replace the winch mechanism but it bolts down from under the bed. If your cable was that rusted then you will have a hard time turning those bolts from the side with a wrench. You might need to remove the bed to get at them with an impact gun.
    The new frames for the recall frame swap come with a chain.
  7. Jan 6, 2022 at 12:53 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Cable or chain, you should put a reminder on your phone's calendar to check it once a year. Usually in the spring I will lower my spare tire, clean it with soap and water, check/fill air pressure, and then lower the entire length of the chain mechanism and wipe it down with a clean but oiled cloth (also oil the "holder piece" that the wheel rests on). I also have a cable lock on my spare that I clean and re-oil at the same time so it doesn't get seized up and impossible to remove later.
  8. Jan 6, 2022 at 6:02 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    2013 Tacoma Access Cab
    Fluid film every year when i drop the spare and reapply when i pit the spare tire back under the bed for the summer. And i also put the spare in the enclosed bed for the winter, easier to get to and no laying in the snow to get to the tire.
    TOMB
    eherlihy, SWPA Tacoma and 2015WhiteOR like this.
  9. Jan 6, 2022 at 7:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The original Toyota's used the reliable chain setup. Later on they switched to a cable that is prone to exactly what you have now a lost spare and broken cable. They then switched back to the old reliable chain / winch.
  10. Jan 6, 2022 at 9:46 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Whenever I'm doing PMs and under the truck lubing things I lower the spare, check the pressure and spray the cable and winch down with motorcycle chain lube. The straw will get the lube in the housing.
    Jimmyh likes this.
  11. Jan 7, 2022 at 12:01 AM
    TacoTuesday1
    FL
    dang I should really hit the thing with WD-40
    don't wanna run it up/down again because fitting the 33 tight against the exhaust was a pain and required a second person tightening the mechanism while pushing backward on the tire
