Cable lock that tailgate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dog tired, Mar 10, 2010.
  1. Mar 10, 2010 at 4:35 AM
    dog tired
    dog tired [OP] Well-Known Member
    NE Ohio
    The hose clamp is good and I figure with the cable lock it will be better.
    Get some plastic coasted cable - Lowes
    High Tensile fence wire locks / links / connectors -- whatever they are called.
    Loop through the tailgate under the bed and use vice grips to squeeze the cable locks closed .
    pic below
    post made so it could be linked
    Tibetan Nomad and Dj Suisav like this.
  2. Mar 10, 2010 at 4:38 AM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    Double bubble baby. Yeah.
    I had a pop and lock on my Dodge, I thought it was junk. Not sure how they are made these days but I like the cable and hose clamp method better.
  3. Mar 10, 2010 at 4:43 AM
    SmoothFox
    DFW TEXAS
    They are called cable ferrules.
  4. Mar 10, 2010 at 4:45 AM
    dog tired
    NE Ohio
    Thanks bro
  5. Feb 4, 2011 at 7:14 PM
    m1keduong
    m1keduong Member
    Whittier, Ca
    05 Tacoma Prerunner TRD Double Cab
    Nice post.
    you know for your hose clamp, i put it the other way around and tightened it up with a wrench, so hopefully it would take them even longer and think twice about stealing my tailgate. I also have the pop n lock.
  6. Feb 6, 2011 at 1:46 PM
    Sideways
    Sideways Well-Known Member
    Maryland
    05 TRD dbl cab
    I like that idea!
  7. Feb 6, 2011 at 2:38 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Smart.
    Only drawback I see is if you had to remove your own tailgate for some reason. But better than losing it to some tweeked jackhole.
  8. Feb 6, 2011 at 3:05 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
  9. Feb 8, 2011 at 6:27 PM
    GeoTaco1
    GeoTaco1 Well-Known Member
    Geo
    11 Tacoma TRD Off Road
    NEW Toyo TIRES Bed Cage to hold 120 LBS of sand and fishing rod holder, window air deflectors, Bug Deflector, & finally Avid Light Bar and step rails....
    I used the clamp, then I added the Bully Taligate lock which uses a key to unlock. Now I have dual protection and the clamp screw is not easily accessible any more:
    I like the cable idea I just need to see how you mount the cable ends???
  10. Jan 1, 2012 at 8:44 PM
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    I like this. I have a power lock pop-lock. Should keep it in place. What are the clamps on the ends for?
  11. Jan 1, 2012 at 9:01 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
  12. Feb 5, 2012 at 7:44 PM
    Bodz
    Bodz Well-Known Member
    Vancouver Island
    2012 TRD 4x4 DCLB
    3" lift, Xd Spy wheels, 265/70/17 Michelins, skid pan, fog lights tint, Flyzeye LED lights, ADVMonster LED lights, tri-fold tonneau, box divider........will it ever end? LOL
    Combining a pop lock with a hose clamp and a master tailgate lock ought to deter the thievin' critters out there.
    Thanks!
  13. Feb 6, 2012 at 3:37 AM
    tpr676
    tpr676 Well-Known Member
  14. Feb 6, 2012 at 8:48 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    I was checking out the Amazon reviews on this. Someone said they put on a 2012 tacoma and that it did not work. He said he could just twist it and the tail gate came off. 3 out of 3 people gave it one star out of 5. It is not rated very well on there.
    Does it work? how do you like it?
  15. Feb 6, 2012 at 9:06 AM
    classic42
    classic42 Well-Known Member
    18 SR5 AC
    Good idea.
  16. Feb 6, 2012 at 9:57 AM
    upthemaiden
    upthemaiden Well-Known Member
    Josh
    Pittsburgh PA
    06 Access cab SR5
    Just bought it!
    Never seen the masterlock/bully tailgate locks, I like them though. I have a pop & lock, which I'm pleased with. It could be built a little sturdier, I'm sure it could be broken with a good tug or two if you really tried, but it's definitely more secure than a hose clamp. I still usually leave the hose clamp on just incase, but I think someday I'll look into one of those other locks so I don't always have to pull out the screwdriver if I want to remove it.
    Belize06 likes this.
  17. Nov 22, 2012 at 5:35 PM
    nine2nine
    nine2nine Well-Known Member
    Greensboro N.C.
    06 TRD Tocoma Sport 4wd
    master lock website says it doesn't fit tacomas
    techbill likes this.
  18. Nov 22, 2012 at 6:24 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    You could use the ferrules to make loops at the ends, and then use a padlock to join them under the truck.
    1Shifter likes this.
  19. Nov 22, 2012 at 9:38 PM
    SkullTaco2012
    SkullTaco2012 Well-Known Member
    2012 DC TRD Off Road
    The master lock website states that it doesn't fit toyota tacoma..... Is anyone using this and does it work on the tacoma?
  20. Nov 22, 2012 at 9:48 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Yes and yes.
