CAD Drawings Help?
Discussion in 'Off-Topic Discussion' started by hobiecat111629, Nov 2, 2016.
  1. Nov 2, 2016 at 2:31 PM
    hobiecat111629
    hobiecat111629 [OP] Well-Known Member
    2015 Tacoma Access Cab
    I'm in IT, I shouldn't be using autocad......but, a customer sent us drawings for their new office and I know enough to open it up in DWG True view. Unfortunately it has 50,000 layers. How the hell do I hide things like ceiling grids, plumbing, and electric?
  2. Nov 2, 2016 at 2:32 PM
    Tatts521
    Tatts521 Well-Known Member
    New Jersey, Jersey Shore
    2012 tacoma-04cbr1000rr-22ktm890duke R-19 wr450f-98rm250
    @Sub-Zero you might be able to answer his question
  3. Nov 2, 2016 at 2:34 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    You have to go to the home button and to the layer state section and its a drop down menu and it should list all the layers there and there is a light bulb next to what you want to hide and you can freeze them also!
    nv529 likes this.
  4. Nov 2, 2016 at 2:35 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    in the command line, LAYMAN (layermanagaer) you should be able to turn off layers
  5. Nov 3, 2016 at 7:49 AM
    moregrizzled
    moregrizzled Lurker
    Located Within The CEP
    2014 4WD
    Short answer: Don't even try.
    Long answer: I deal with CAD messes like this every day. The problem is that there could easily be 50 different versions of the project in the same drawing file, with absolutely NO information to tell you which layers contain the FINAL version of the project. Throw in the fact that most people who create these CAD messes are complete and total slobs with no clue what they are doing, and the chances of getting screwed go way up.
    It is possible that the drawing you received is clean, concise and accurate. But if it really does have a zillion layers, then it probably is a total mess.
    Don't get hosed. Insist on a plain, un-layered PDF file of the drawing, that shows clearly and concisely what is to be built. Save a copy of the file on a secure server, with the "read-only" attribute set, and stored in a folder that identifies the source and the date/time you got it. That way, when the project is half-built and there is a discrepancy over what you bid on and what they THINK you bid on, you can pull out a copy of the original PDF that contains the project as quoted.
    Bottom line: CYA at all times when it comes to CAD files. Trust me on this...
    Jim
    Speaking from a secure undisclosed location.
    rleete and nv529 like this.
  6. Nov 3, 2016 at 12:45 PM
    hobiecat111629
    Thank you! Took a long time to hide what I didn't want, but I finally got it "cleaned" up enough to plot it scribble notes and markup for our technicians installing the network gear.
    moe2o4[QUOTED] likes this.
  7. Nov 3, 2016 at 12:49 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    what's the command that opens a new viewport into the model on paperspace?
  8. Nov 3, 2016 at 12:50 PM
    hobiecat111629
    Oh, it's a total mess. Not only did they send me all 15 suites in the building, when my customer only has 2, but a million layers for different versions and stages of demolition. A nice clean PDF would have been sweet, but it took me 3 weeks to get what I have.
  9. Nov 3, 2016 at 12:54 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Also if you want to try freezing things that are just in the paperspace you can open the viewport or just use the model space and then type LAYFRZ and anything you click after that will freeze all components on that said layer. Its a quick way to freeze things if you dont know exactly what layer things are on but want them turned off.
    Coot
  10. Nov 3, 2016 at 12:57 PM
    moe2o4
    Corey
    Pittsburgh PA
  11. Nov 3, 2016 at 12:59 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
  12. Nov 3, 2016 at 1:02 PM
    ramonortiz55
    Ramon
    Texas
    stock
  13. Nov 3, 2016 at 1:04 PM
    ramonortiz55
    Ramon
    Texas
    stock
    My Designer is out of the office today, so im doing the design/drafting :spy:
    Silver02Taco and moe2o4 like this.
  14. Nov 3, 2016 at 1:05 PM
    moe2o4
    Corey
    Pittsburgh PA
    :rofl:
