CAI TRD 2010 & MAF Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dr. Mike, Aug 10, 2010.
  1. Aug 10, 2010 at 7:42 AM
    Dr. Mike
    Dr. Mike [OP] Active Member
    Paraguay
    Silver 4WD TRD off road
    Bilstein 5100 ,Xenon lights,rear tonneau cover,DNX 9140,ccd 2000,Garmin gpsmap 276c,rear AAL,front bull bar,hella luminator,tinted windows, pl8520.
    Since 2 months ago, i installed my CAI TRD 2010 and few miles later appeared check engine light (CEL) i try: clean MAF sensor , check all installation,disconnect battery and nothing......last chance is change MAF sensor.........anyone knows any solution before replacing the MAF sensor?.:(
  2. Aug 10, 2010 at 7:46 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Reinstall stock intake and see if it goes away.
    My guess is an install issue..are there any leaks? Everything tight on the throttle body, vacuum line installed correctly?
  3. Aug 10, 2010 at 7:59 AM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    How about finding out what code is being thrown? Why replace a MAF sensor when maybe that is not even the issue?
  4. Aug 10, 2010 at 8:06 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    and whats the code say
  5. Aug 10, 2010 at 9:16 AM
    cotruckin
    cotruckin Well-Known Member
    Westminster, CO.
    Lifted 06 TRD Sport
    Bilstein 5100 Lift with rear 1" blocks, ARE Z series topper with Yakima rack and Rola basket, some audio equipment, some more goodies
    I have had the same thing with my K&N intake. I have replaced with the stock and it goes away. I have tried cleaning the trottle body, the MAF sensor, check and rechecked all lines. Sometimes when driving it will go off, but then come back on. I got the code checked and it is saying vaccuum leak, so I need to get some clamps for the lines just to be sure everything is as tight as it can be. I think I am going to dump the K&N for a TRD soon though.
  6. Aug 10, 2010 at 9:27 AM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Remember the exact code number? Very interested as I have been considering CAI and K&N is on the list.There is the vacum hose on the back side of the stock Air cleaner housing. I think that is that the only vacum line. I would make sure where the line connects to on the K&N
    (assuming it is resused) is not blocked.
  7. Aug 10, 2010 at 9:33 AM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    If you have the type of CAI that uses oil on the filter element and you over oil it, or it comes with too much oil on it from the factory, the oil will get pulled into the MAF and throw the check engine light on.
    They make regular MAF cleaner that comes in an aerosol. I would suggest using that and drying some of the oil out of the filter element.
  8. Aug 10, 2010 at 9:39 AM
    YumaTRD
    YumaTRD 22R...Legends never die
    David
    El Cajon, CA hometown Yuma, AZ
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO's
    I had a CEL Light from my Volant intake. I had to purchase the URD calibrator so the MAF sensor got a good reading. I believe the code that kept poping up was P1001
  9. Aug 10, 2010 at 1:37 PM
    Dr. Mike
    Paraguay
    I think the re installation may be the answer and is cheap to change the MAF sensor. Tomorrow I'll try re-installing everything.:confused:
  10. Aug 10, 2010 at 1:50 PM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    Look into a Pro dry filter, no oil, no MAF fouling.
  11. Aug 10, 2010 at 1:50 PM
    Dr. Mike
    Paraguay
    No leaks, tight like a submarine door.
  12. Aug 10, 2010 at 1:52 PM
    Dr. Mike
    Paraguay
    New style, 2010.
  13. Aug 10, 2010 at 1:56 PM
    Dr. Mike
    Paraguay
    Yes, is use oil , but how can i know it is over oiled? I cleaned the MAF sensor twice times and always go off but then .....is there again CEL light.
  14. Aug 10, 2010 at 1:58 PM
    Dr. Mike
    Paraguay
    Yes ,is on my list too.:(
  15. Aug 10, 2010 at 2:26 PM
    Dr. Mike
    Paraguay
    Not yet, tomorrow.
  16. Aug 10, 2010 at 2:32 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    I'd be interested to find out what's causing this as well. I was thinking of getting a TRD CAI.
  17. Aug 10, 2010 at 2:34 PM
    iSTIZO99
    Jax, FL
    How do you tell which is which?
  18. Aug 10, 2010 at 2:55 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I'm thinkin you may have damaged the maf sensor.
  19. Aug 11, 2010 at 5:09 AM
    Dr. Mike
    Paraguay
    The old had the aluminum cover and the new has the plastic cover with red letters and an indicator of filter status.I think the filter element is also different.
  20. Aug 11, 2010 at 5:15 AM
    Dr. Mike
    Paraguay
    The code is P0101 , any suggestions:confused:
