CAI V.S. Exhaust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Xx702xX, Jul 23, 2017.
  1. Jul 23, 2017 at 11:54 AM
    Xx702xX
    Xx702xX [OP] Well-Known Member
    I have 2016 Access Cab Sr 5 4X4. Im looking to either do a CAI( S&B, Afe or TRD in order of favoritism.not thinking K&n because i wheel to much) or exhaust set up. I haven't quite decided which one yet. Im looking to make my beast sound more like a beast lol and if i can get boosted performance then that would be awesome to. I have read a ton on the forums on the topics so i know there is a lot of haters of CAI. one thing is I do have a 125,000 miles 7 year wrap around warrenty. So I'm trying to avoid giving them to many reasons to give me shit on the warranty if i ever have problems. Another concern I have is that because I do like to go out wheeling a bit is that an exhaust might mess with my clearance. Looking for Pro V.s. Cons. And im not trying to kill the bank to much.
    Thank you everyone!!!
  2. Jul 23, 2017 at 11:58 AM
    Bishop84
    Bishop84 Well-Known Member
    Make sure to search around on youtube for sound.
    CAI's provide and nice throttle sound up front, but some of the cheaper ones will cause a loud "drone" in the cabin on the Taco's. I would only suggest an AFE intake right now.
    The exhausts on these trucks aren't for everyone, I have yet to hear any tacoma that sounds good with exhaust, but the general consensus right now is the TRD exhaust is not worth the money. Look towards magnaflow for this, again check youtube.
    shakerhood likes this.
  3. Jul 23, 2017 at 12:02 PM
    Xx702xX
    Im having trouble finding unbiased sound clips lol. Im thinking S&B or Afe. Why would you do AFE??
    There is a used magnaflow cat back exhaust for 450 i was looking at.
  4. Jul 23, 2017 at 12:04 PM
    Bishop84
    I work on Taco's and the AFE is the quality and sound that I like to see from an aftermarket, I can't stand the K&N intakes, they are cheap and rattle the interior.
    I'd say go with the exhaust as long as you've heard it, but hang on to the oem exhaust.
  5. Jul 23, 2017 at 12:18 PM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    put on the MBRP cat back turn down exhaust with the additional resonator too try to cut down on drone but its still loud. if my stock shit didnt have holes in it i would have stayed with it.
    Fatchrisfbm and Xx702xX[OP] like this.
  6. Jul 23, 2017 at 12:20 PM
    Xx702xX
    Good to know I was kind of leaning away from it anyways.
  7. Jul 23, 2017 at 12:38 PM
    rewted
    rewted Well-Known Member
    2017 Black TRD Off-Road Double Cab Short Bed
    Warn Zeon 10-S, BFG KO2 265/75/16, Bakflip MX4, Split Dual Battery System, TRD Pro Grille, Tokonsha P3 Brake Controller, ScanGauge II
    Anything other than stock exhaust on this truck sounds like shit, and even stock doesn't sound great.
    You will become what everyone hates if you rice out this truck.
    epa4wd and shakerhood like this.
  8. Jul 23, 2017 at 12:46 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Stock exhaust, cut it after the axle bend.
    bullaculla likes this.
  9. Jul 23, 2017 at 12:47 PM
    santas212
    Georgetown, CT
    i second that ^
    stun gun[QUOTED] likes this.
  10. Jul 23, 2017 at 1:23 PM
    Xx702xX
    Wont that make it super loud? Could that mess up the warranty at all?
  11. Jul 23, 2017 at 1:28 PM
    santas212
    Georgetown, CT
    your only chopping it like a foot or two short, just enough so its not routing out behind the rear tire. the stock muffler will still be in place un touched. i cant imagine this minor change would void warranty. you might see a slight increase in noise but only because its dumping under truck and not out the side. but with stock muffler it is probably minimal.
    stun gun likes this.
  12. Jul 23, 2017 at 1:30 PM
    stun gun
    Aaronski
    Tacomas.
    No sound difference, better departure. Don't think it'll mess up the warranty
  13. Jul 23, 2017 at 1:40 PM
    Xx702xX
    What do you mean by departure? Are you referring to having more clearance in the back for off roading?
  14. Jul 23, 2017 at 1:44 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Yes. The pipe no longer sticks out under the truck fender.
    Also, your stock intake is a cai
  15. Jul 23, 2017 at 1:58 PM
    stun gun
    Aaronski
    Tacomas.
    Yes
  16. Jul 23, 2017 at 2:30 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    If money isn't an issue look into the URD Spec U exhaust kit.. it eliminates 2 of the cats and get rid of the factory y pipe that hangs low and can get dinged while off roading
    TacoRD16 likes this.
  17. Jul 23, 2017 at 2:36 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Exactly, every aftermarket exhaust for this 3.5 does not sound good at all.
  18. Jul 23, 2017 at 2:38 PM
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    I have the s&b cai and a flowmaster 40 series exhaust. I really enjoy both and they compliment each other real well...
    That being said.. If i had to choose only 1... The exhaust.. Hands down my favorite mod.
    I looked at loads of exhaust and finally settled on a delta flow... But when i got to the muffler shop i listened to a (iirc) dodge dakota that just had a regular 40 installed... 6cyl as well... Sounded great! The guy told me either would be about the same price but if i wanted that deep low bassy sound i should get the regular 40... I did and love it. When i traded my 2016 in for a 2017 the first thing i did was another 40 series.
    Bullshit. My truck sounds like a real truck. But feel free to enjoy your moped. :D
    blackrifle76 likes this.
  19. Jul 23, 2017 at 2:44 PM
    modifiedtaco
    Alex
  20. Jul 23, 2017 at 2:46 PM
    modifiedtaco
    Alex
    I don't mind the sound.. to each their own I guess
    Gettin Lost likes this.
