CAI
Discussion in 'Performance and Tuning' started by ROMYER8313, Jan 22, 2013.
  1. Jan 22, 2013 at 11:25 AM
    ROMYER8313
    ROMYER8313 [OP] Active Member
    robert
    medford oregon
    08 sport package
    supercharger, 3inch lift, Doug thorley long tube headers and Magnaflow pro series off road exhaust. urd 2.55 pulley, ucon ems, upgraded urd fuel pump, urd seventh injector system, 61lb mulit-fuel fuel injectors, and AFE cai.
    i was wanting to instal either a trd cai or a AFE cai. i was concerned because i was told by toyota that the trd cai was not compatible with my 2008 tacoma and my supercharger. i was looking on line and there were some problems with the cai and the supercharger and the cai would cause a lean code. is there anything that i can do to install the afe or the trd cai without having these cai causing a lean code?
  2. Jan 22, 2013 at 11:29 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The afe stage 2 Si is compatable with the trd blower.....lots of guys here and on xru run that setup.....the afe stage 2 Si and original style trd intake work well, its just the newer style trd intake was a hack job and k&n didn't do their homework when they designed it.
    If in doubt u can call gadget at urdusa.com
    He can make a skateboard supersonic if u give him some bubble gum, a no2 pencil and duct tape.
  3. Jan 22, 2013 at 11:33 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Btw, the older style trd and afe stage 2 si are 99% the same.....they are both made by afe....TRD does not make intakes, they contract others to do it.
    Afe has a small port in front that u can cover or leave open (google pics)....the older trd is fully sealed but otherwise looks identical for the most part.
    The new trd is flawed, made by k&n, has a goofy lil indicator on the box for filter life, clips on the top, and thrown cel under boost.........gadget at urd can sell u a maf calibrator that's tuned to fix this issue too.
    Id just use the afe tho......buy it from gadget
  4. Jan 23, 2013 at 2:04 PM
    ROMYER8313
    robert
    medford oregon
    08 sport package
    Thanks for the info, I called and talked to gadget and he confirmed that the AFE was compatible.
  5. Jan 23, 2013 at 5:22 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Cool beans
  6. Jan 24, 2013 at 7:40 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If I recall correctly Toyota does not support a CAI with the SC. So unless you are under warranty, should not be an issue.
