CAI
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jzone71, Jun 11, 2023.
  1. Jun 11, 2023 at 6:43 PM
    jzone71
    jzone71 [OP] Well-Known Member
    Jeff
    Thoughts on best bang for the buck
  2. Jun 11, 2023 at 6:44 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Get a tune..
  3. Jun 11, 2023 at 6:45 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
  4. Jun 11, 2023 at 6:46 PM
    jzone71
    Jeff
    After market
  5. Jun 11, 2023 at 6:46 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Someone just created a new thread about this a few hours ago I think. There are probably hundreds of threads in total on the topic just search around.
    soggyBottom likes this.
  6. Jun 11, 2023 at 6:47 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It doesn’t do anything for you. Spend the money on a tune instead if you want to see actual performance gains and not just some noise.
    Road_Warrior likes this.
  7. Jun 11, 2023 at 6:48 PM
    jzone71
    Jeff
    Tune,Thats what I was thinking also
  8. Jun 11, 2023 at 6:50 PM
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    Save some money and get a tune then. Circle back afterward...
  9. Jun 11, 2023 at 6:51 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The 3.5 V6 Tacoma uses the same air filter as a 5.7 V8 Tundra so there is plenty of flow available.
    Aftermarket intakes do add noise however it that it an interest.
    Junkhead, DetroitDarin and Chew like this.
  10. Jun 11, 2023 at 6:54 PM
    happyvirus
    happyvirus Well-Known Member
    Do tunes help MT as well? If all it does is change shift points to access existing power, the gains on MT would be minimal.
  11. Jun 12, 2023 at 4:26 AM
    auskip07
    Skip
    Atlanta, Ga
    Just a heads up,
    you're better off doing some research vs hi-jacking another thread that most people will ignore. @PapaRee will give you some info about what he adjusts for the MT tune for (KDmax tunes) I run his tune and it does make a difference
    eurowner, Chew and PapaRee like this.
  12. Jun 12, 2023 at 4:53 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Your truck comes with a CAI from the factory. It's already pulling air from the right fender well as opposed to the engine compartment. If you want to increase the air flow get an Intake Flow Accelerator from the parts counter at your dealership or from one of the many online sources for about $30
    bkhlrTaco's and Chew like this.
  13. Jun 21, 2023 at 3:56 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    After looking for a cai myself and looking at the various designs of after market cai's. I've concluded, for myself, that the factory intake on my 2016 trd is honestly a better setup.
    Like you said. It's pulling cold air from the fender while these other open box concepts appear to draw hot engine air.
    One man's opinion.
    Chew and FL_TRD Sport[QUOTED] like this.
