Calamity Ganon build thread, sorta bs thread? with a sprinkling of Sumi the HX
Discussion in '2nd Gen. Builds (2005-2015)' started by Calamity_taco, Jan 15, 2019.
  1. Nov 9, 2021 at 1:46 PM
    #481
    Adventure4x4
    Adventure4x4 Well-Known Member
    Adam
    San Antonio, TX
    2013 TRD off road MT
    Are they a form of a lock nut? I like stover nuts (that sounded weird haha). Also, fyi, no one really calls them "limiter" straps. Refer to them as "limit" straps instead ;)
    Slashaar likes this.
  2. Nov 9, 2021 at 1:55 PM
    #482
    Calamity_taco
    Calamity_taco [OP] your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 97 & 98 EK, 23 Klx300R, 2014 Bolt R-spec
    just a couple of things tbh
    limit limiter same thing lol
    and its a two nut system where one tightens it down to where you want it to hold at then the other is suppose to lock it down buuut i just noticed they are way loose now
  3. Nov 9, 2021 at 2:07 PM
    #483
    Adventure4x4
    Adam
    San Antonio, TX
    If you can't find stover nuts to replace those, I would try a lock washer with one nut. The double nut method is good for installing studs but not necessarily for maintaining tension under vibratory conditions.
    Edit: only one stover nut as well.
  4. Nov 9, 2021 at 2:09 PM
    #484
    Calamity_taco
    Jacob
    ya idk why thats how it came but meh also whats a stover nut lol
  5. Nov 9, 2021 at 2:10 PM
    #485
    Adventure4x4
    Adam
    San Antonio, TX
    Really?? Wow, I can't believe it came like that haha.
    Stover nut simply has an oval hole instead of a round hole
  6. Nov 9, 2021 at 2:11 PM
    #486
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    If you weld them they wont move :rofl:
    Or Red Lock tite. :rofl:
    Shellshock and Adventure4x4 like this.
  7. Nov 9, 2021 at 2:11 PM
    #487
    Adventure4x4
    Adam
    San Antonio, TX
    Yeah loctite works as well lol
    Slashaar[QUOTED] likes this.
  8. Nov 9, 2021 at 2:12 PM
    #488
    Calamity_taco
    Jacob
    you see they had blue lock tite and i thought it would be fine but nope lol
  9. Nov 9, 2021 at 2:12 PM
    #489
    Calamity_taco
    Jacob
    interesting.
    and ya thats how kartek sent it
  10. Nov 9, 2021 at 2:12 PM
    #490
    Adventure4x4
    Adam
    San Antonio, TX
    :rofl:
  11. Nov 9, 2021 at 2:13 PM
    #491
    Adventure4x4
    Adam
    San Antonio, TX
    and now I'm really surprised. Kartek should know better. Can you post a picture?
  12. Nov 9, 2021 at 2:17 PM
    #492
    Adventure4x4
    Adam
    San Antonio, TX
    Calamity_taco[OP] likes this.
  13. Nov 9, 2021 at 2:18 PM
    #493
    Adventure4x4
    Adam
    San Antonio, TX
    This is my bad. Dont use the stover. Try the loctite. I'm wondering if the straps are set up correctly. There's nothing hitting them or constantly being stretched?
  14. Nov 9, 2021 at 2:19 PM
    #494
    Calamity_taco
    Jacob
    yes mine is the adjustable one since i didnt know what exactly i needed
  15. Nov 9, 2021 at 2:19 PM
    #495
    Calamity_taco
    Jacob
    ya lol
  16. Nov 9, 2021 at 2:21 PM
    #496
    Adventure4x4
    Adam
    San Antonio, TX
    Yeah that's a good route to go. Try the loctite and see if that does it. Also, keep am eye on any where points. There is a spring to help maintain tension on the nuts as well.
  17. Nov 9, 2021 at 2:21 PM
    #497
    Slashaar
    Josh
    Kansas City, MO
    they are constantly in contact with his tie rod.
  18. Nov 9, 2021 at 2:22 PM
    #498
    Calamity_taco
    Jacob
    they are not they are close yes but they are not touching
  19. Nov 9, 2021 at 2:23 PM
    #499
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Someone made a build thread for a shitbox?! What’s going on in here?!
    Shellshock and Slashaar like this.
  20. Nov 9, 2021 at 2:23 PM
    #500
    Calamity_taco
    Jacob
    i need to cut the mounts off and angle them better tbh we welded them on with following a picture from online and i personally dont like the angle because they are very close to my tie rod but they dont touch even under flex just are very close
