Cali Raised catalytic guards transmission cross member torque specs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoguy05, Feb 19, 2023.
  1. Feb 19, 2023 at 1:14 PM
    Tacoguy05
    Tacoguy05 [OP] Active Member
    2018 TRD Sport
    Installed the Cali Raised cat guards on my 2018 Tacoma Sport.
    Does anyone know what the torque specs are for the 4 transmission cross member bolts?
    Can’t seem to find it anywhere.
    thanks.
    MagrayAC likes this.
  2. Feb 19, 2023 at 8:12 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I know I hate it when someone says to Google something, but somewhere on this site is a 2nd generation file with most torque settings called out. I've seen it, I know it is here, but where? Second and third generation should be the same for something as simple as what you are looking for. Recommend you download the complete file when you or someone directs you to it. Also consult the grade of bolt and size in the future and with the exception of I believe engine head bolts, they are all the same torque for size and grade. I realize this does not help you with your current dilemma, but you will be better off in the future with this simple knowledge.
  3. Feb 19, 2023 at 8:14 PM
    Grimble27
    Grimble27 Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    Don’t quote me, but I believe the crossmember bolts are 34 or 37 ft lbs. I don’t know what the bolt torque spec is for the bolts you loosen that hold in the transmission. I just did all of them snug as close as I could to the feel of them when I first loosened them.
  4. Feb 19, 2023 at 8:18 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    71tattooguy likes this.
  5. Feb 20, 2023 at 2:30 AM
    Tacoguy05
    2018 TRD Sport
    I appreciate all the responses. I saw the 2nd gen bolts were torqued to 40lbs, but wasn’t sure if the 3rd gen was different. Saw I torched to the 40lbs.
  6. Feb 20, 2023 at 2:59 AM
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Worrying about torque specs for transmission crossmember bolts. Lolz. This place
  7. Feb 20, 2023 at 10:02 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    35 pound feet if you are re-using factory screws
    if you're using security screws, only snug not 35 pound feet (ask how I know)
