CALI RAISED LED BED MOLLE SYSTEM FOR 2005-2023 TOYOTA TACOMA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CaliRaisedLed, Mar 19, 2018.
  1. Mar 20, 2018 at 7:00 PM
    #41
    Thompson486
    Thompson486 Well-Known Member
    Sherwood Park, AB
    2022 AC Off-Road Blue Crush
    Damn... Won’t be able to afgord these anytime soon. With shipping to Canada via UPS on top as well as UPS’ insane brokerage fees.
    Guess I’ll be waiting a while before I can buy em.
  2. Mar 20, 2018 at 7:23 PM
    #42
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    For Canada we do about $20 for shipping
  3. Mar 20, 2018 at 7:32 PM
    #43
    Thompson486
    Sherwood Park, AB
    That’s not bad for shipping.
    Too bad UPS would charge me $200 for brokerage.
    Would you ship with Fedex? They’re much more reasonable on the brokerage fees.
  4. Mar 21, 2018 at 6:48 AM
    #44
    Swisscosmo
    Swisscosmo Well-Known Member
    Edmonton AB
    2015 Tacoma AC OR
    Subbed. I’d be interested to know also.
  5. Mar 21, 2018 at 7:01 AM
    #45
    Thompson486
    Sherwood Park, AB
    Group buy?
    mtmudrunner and OneFastGeek like this.
  6. Mar 21, 2018 at 7:20 AM
    #46
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    More Molle for the Tacoma, awesome!!! With @docloco awesome rear cab panel, @mesojdm forthcoming interior roof panel, @Yo_Hec console panels, and now @CaliRaisedLed bed panels, this is great.
    ready6delta, fatfurious2 and docloco like this.
  7. Mar 21, 2018 at 7:24 AM
    #47
    OneFastGeek
    2010 TRD Sport 4x4
    Do you offer a non-powder coated option at a discount? I'd like to take them to a local shop to color match my bed rack.
    fatfurious2 and skatefreak282 like this.
  8. Mar 21, 2018 at 7:52 AM
    #48
    Swisscosmo
    Edmonton AB
    2015 Tacoma AC OR
    Definitly would be down to do that.
    Atlas86 and Thompson486[QUOTED] like this.
  9. Mar 21, 2018 at 8:45 AM
    #49
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Any dimensions on these. Thanks
  10. Mar 21, 2018 at 10:20 AM
    #50
    CaliRaisedLed
    Jake
    Texas (DFW)
    Shoot us a PM
    fatfurious2 likes this.
  11. Mar 21, 2018 at 10:21 AM
    #51
    CaliRaisedLed
    Jake
    Texas (DFW)
    Shoot us a pm
    skatefreak282 likes this.
  12. Mar 21, 2018 at 10:27 AM
    #52
    CaliRaisedLed
    Jake
    Texas (DFW)
    This will be an option 99.99 at your door.
  13. Mar 21, 2018 at 11:29 AM
    #53
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
  14. Mar 21, 2018 at 11:43 AM
    #54
    MojaveMadman
    MojaveMadman Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Hey everyone,
    Chris here from Cali Raised. You may remember me formerly selling LED mounts as Apex Fabworks. I am working on the Cali Raised team now as their product engineer and a few other rolls.
    I wanted to share with you guys a detailed explanation of the Molle system so you guys can get an idea of what we have to offer, and why we think it's a great product.
    Let me start with some facts. Jake has mentioned some already.
    Material: 10 gauge cold rolled steel, 0.14" in thickness to be exact
    Manufacturing Process: CNC laser cut, CNC formed on our Amada press brake. All done in the USA by us and a couple local processing companies.
    Coating: Sand blasted and powder coated semi gloss black mini texture.
    Hardware: All specifically spec'd for each need. All zinc coated for anti corrosion.
    Dimensions: Rear panel 30" x 12" Full System 54" x 12" when assembled
    So to give you guys the break down I am going to go through a few things. First I am going to start with hardware. The Molle system and rear panel both use some very specific high quality hardware. From the simple stuff down to the more complex. Everything has the correct washers that are required and all fasteners use a lock nut to ensure they will stay tight. We also use high quality T-Slot nuts to ensure that you get a very solid mount in the rail. Additionally a VERY important feature to note is the use of rubber bumpers. Every accessory mount I have seen on the market for the Tacoma bed seems to have a metal flange near the bottom that contacts the bed as a support. While this does work as a support you have metal contact on your composite bed. Over time as the mounts vibrate around, especially under load this can cause damage and rub markings to the bed surface. With the rubber bumpers you have zero damage and you can remove the system with zero blemishes to the bed.
    You can also see in the pictures our optional High Lift Jack hardware kit. Designed to stay in place when the jack is not in use, but easily allow install and removal if needed with the simple turn of a knob.
    Next I want to showcase the system and some of the features. Ultimately the sky is the limit on these and you will be able to do a lot more than we show you, we can't wait to see what you think of. So first an important detail to point out is where the Molle system bolts to the accessory rail. Notice it is three tabs that seem to be in weird spots. This is all intentional. The Molle system is designed to work WITH most bed racks. If the bed rack system uses two or three posts and doesn't cover the entire accessory rail, then it should not interfere. We don't know the details on all racks on the market, but this should stay out of the way of most we reviewed. Also with these tabs it still allows the use of the accessory rail hooks. You can still install and move the hooks around and use them as you need. Sorry guys with bed covers that drop the rail system down, we do not think this is compatible. The space is limited and we wanted to maximize mounting options.
    Next you will see the obvious Molle rectangles. These are 1.5" wide to accept standard Molle bags. Also you see the 1/2" slotted holes in 6 specific locations. this is so jacks can be mounted in a few places along with other heavier accessories. Then there are the 1/4" holes all over the rack. These work great for a large number of accessories and also many of the Quick Fist offerings. Your imagination is the limit here.
    Next I have included a couple of alternate views so you can see what is going on. While these are largely flat panels you can see there is a lot going on here. These are designed to fit the shape of the bed and to allow things to be mounted in 3D space while keeping clutter of the bed of the truck.
    Last I have a few examples of the panels separately. First is the rear panel that is offered as a stand alone. This is a good demonstration of what you will get when ordering just the rear panel. It is a very easy install with four mounting locations and then you can start mounting all your fun stuff. The second picture is the extension that is available if you do the entire system. This one has a lot more hardware included and allows for the mounting of longer items like fishing poles, shovels, axes, jacks, etc.
    If you guys have any technical questions please feel free to post them up or shoot me a DM. I will do my best to get to them quickly and provide the details you need!
  15. Mar 21, 2018 at 11:52 AM
    #55
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I know that more short beds are out there but will you offer a long bed model or will that extra foot or so make a difference?
  16. Mar 21, 2018 at 11:54 AM
    #56
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    We had intended on doing a long bed version but after we installed the version above in a long bed we determined it was not needed. It's pretty far back in there and most will not be mounting bags back there. You are still able to mount all the long accessories with this version so it made sense to just end at the fender. It still looks great, doesn't look out of place or short. Plus a long bed version would be more expensive, this way you save!
    mtmudrunner[QUOTED] likes this.
  17. Mar 21, 2018 at 12:03 PM
    #57
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Can I get some o/c measurements from the end of the bed rail where the mounting tabs hit and how wide the tabs are? Does it come with the rail hardware?
    Need to see if it will clear what I have mounted already on the rail. Thanks
  18. Mar 21, 2018 at 12:05 PM
    #58
    MojaveMadman
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
  19. Mar 21, 2018 at 12:13 PM
    #59
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    inesshell[QUOTED] likes this.
  20. Mar 21, 2018 at 12:22 PM
    #60
    RCRcer
    2015 OR DC
    Thanks @MojaveMadman! Damn, not gonna work for me with my current setup.
    Great looking functional product you made there.
