Cali Raised LED Side Projecting LED Pods *NEW PRODUCT*
Discussion in 'Lighting' started by CaliRaisedLed, Apr 6, 2017.
What is your favorite Cali Raised Led Product?
  1. Bumper LED Light bar
    48 vote(s)
    26.4%
  2. Ditch Pods
    45 vote(s)
    24.7%
  3. THESE!!!!!
    89 vote(s)
    48.9%
  1. Oct 12, 2018 at 7:03 AM
    #661
    joeytheskybison
    joeytheskybison Member
    Joey
    SoCal
    2018 Tacoma 4x4 OR DCSB
    CaliRaised Ditch Brackets w/ Side projecting pods. CaliRaised Rock Sliders. TRD Pro Grill. Uniden CB w/ Firestik Antenna.
    Green - White.
    Red/Yellow (closest to green) - Blue
    Red/Yellow (closest to black) - to Add-a-fuse
    Black - Black
    You tap the add-a-fuse into the panel right under the switch blank (I believe fuse 4a or 5a) and it will allow the OEM switch to light up with all your other stock switches when you turn your headlights on.
    If you don't care about that little detail and want it lit all the time then wire both red/yellows to blue. And if you don't want the switch lit at all until your ditch lights are actually on then only wire the red/yellow closest to green to the blue and leave the other red/yellow unconnected. Hope that made sense.
  2. Oct 12, 2018 at 8:02 AM
    #662
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Had to read it a couple of times, but yes, it did, haha. Thanks for the tip. I already wired it in, but for the future if i want to change it or add another switch/light, I'll try to remember this post. Thanks!
  3. Oct 12, 2018 at 8:09 AM
    #663
    joeytheskybison
    Joey
    SoCal
    No problem, It took me a while to figure it out. I'm sure its all out there but I could not for the life of me find a schematic on the ditch light install.
  4. Oct 12, 2018 at 1:01 PM
    #664
    CaliRaisedLed
    CaliRaisedLed [OP] Well-Known Member Vendor
    Jake
    Texas (DFW)
    Thanks for helping out guys!
  5. Oct 12, 2018 at 1:07 PM
    #665
    DarthPow
    Am I correct in that the two in the middle of the switch attach to the the middle wire in the harness, regardless of the colors? and then the black to black for ground, and then the others connect?
  6. Oct 12, 2018 at 1:13 PM
    #666
    CaliRaisedLed
    Jake
    Texas (DFW)
    That is correct!
    DarthPow[QUOTED] likes this.
  7. Oct 13, 2018 at 5:20 PM
    #667
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Got mine installed today, man they’re bright.
    Does anyone know where I can get a ditch light switch that will fit the center console blanks? They’re more square than the switch provided in the kit.
    I have the trd offroad so all my switches on the left side are taken. Im trying to put it right next to the atrac button behind the shifter
  8. Oct 15, 2018 at 9:15 AM
    #668
    CaliRaisedLed
    Jake
    Texas (DFW)
    https://caliraisedled.com/collectio...all-style-toyota-oem-style-ditch-light-switch
    Here you go!
    Let me know if you have any questions.
    Thanks
  9. Oct 15, 2018 at 12:29 PM
    #669
    CaliRaisedLed
    Jake
    Texas (DFW)
  10. Oct 15, 2018 at 12:43 PM
    #670
    Larueminati
    Western MA.
    Jeez I wish I saw that on the order entry dropdowns, it's not listed on there is it? I ordered one off Amazon already, would have ordered it from you but I didn't see it on the site. I checked thru accessories and it doesn't list the small button either.
    Either way, I love the lights. Having the wrong button was minor, using it in the meantime until the small one shows up.
  11. Oct 24, 2018 at 12:53 PM
    #671
    CaliRaisedLed
    Jake
    Texas (DFW)
    Thank you for choosing us!
    Lets see some pictures when you get them!
  12. Oct 25, 2018 at 11:53 AM
    #672
    CaliRaisedLed
    Jake
    Texas (DFW)
    https://caliraisedled.com/collections/rock-sliders
    Here are our 0-degree rock sliders that we installed and got them Line-x.
    Our sliders are made the best way we know how for the best fit and protection standard, no up charge. You can choose between Bolt-On or Weld-On. Bolt-On sliders come with all the required hardware you need for the install and are installed with zero modification to your truck
  13. Oct 26, 2018 at 1:52 PM
    #673
    CaliRaisedLed
    Jake
    Texas (DFW)
  14. Oct 29, 2018 at 1:30 PM
    #674
    CaliRaisedLed
    Jake
    Texas (DFW)
  15. Oct 31, 2018 at 2:20 PM
    #675
    CaliRaisedLed
    Jake
    Texas (DFW)
  16. Nov 25, 2018 at 7:54 PM
    #676
    Capt Tacoma
    Capt Tacoma Well-Known Member
    2017 TRD Sport DCSB
    I already have the caliraised 32" led light bar, is there anyway to wire these ditch lights to the light bar switch?
    CaliRaisedLed[OP] likes this.
  17. Nov 26, 2018 at 3:24 PM
    #677
    CaliRaisedLed
    Jake
    Texas (DFW)
    Capt Tacoma[QUOTED] likes this.
  18. Dec 5, 2018 at 6:37 PM
    #678
    Polarbear84
    Polarbear84 Member
    I just got mine installed, but I can't figure out what the 2 hex bolt with 2 lock nut is used for. It was included in the same packaging as the low profile brackets. This is for the ditch lights.
  19. Dec 6, 2018 at 4:56 PM
    #679
    Fisherman983
    Fisherman983 Well-Known Member
    Alex
    2013 Tacoma Trd sport
    None yet.
    do you have any pics from inside the cab, showing hood glare? if there is any.
  20. Dec 10, 2018 at 3:49 PM
    #680
    CaliRaisedLed
    Jake
    Texas (DFW)
    Those are to attach the Light and the Lo profile brackets together. The hardware is a little smaller than the ones provided with the actual lights.
