Cali raised switch and teeny wires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitepony04, Jun 7, 2019.
  1. Jun 10, 2019 at 1:29 PM
    #41
    riverrockar
    riverrockar Well-Known Member
    Indiana
    2017 Tacoma DCSB TRD Sport INFERNO
    Twist caps have no place in a motor vehicle. None. Ever.
    the_dau and Boghog1 like this.
  2. Jun 11, 2019 at 1:14 PM
    #42
    sdfuller88
    sdfuller88 Well-Known Member
    Reno, NV
    They're definitely not the best solution but I do use them for temporary wiring installations until I have all of the needed components in to solder/crimp.
    Whats the reasoning for your viewpoint on them?
  3. Jun 11, 2019 at 1:44 PM
    #43
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    They’re usually used in a box where the wires are clamped on entry to the box and the box is fixed to framing that doesn’t move, wiggle, vibrate, etc. Prior to the box romex is stapled within 6” of the box. Wire nuts are connectors only and should not be used where the connection can get tugged on or vibrate loose. They just aren’t the best thing to use for automotive connectors. With all the other choices available they shouldn’t even be considered. That said, the Darwin awards are always accepting entries.
    the_dau likes this.
  4. Jun 11, 2019 at 4:51 PM
    #44
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    They don't cut like the other connectors, the tip spreads the wire and keeps a tight grip on it. And the wires are so small already just cutting the insulation off you risk cutting a few strands.
    I do solder most the time, Especially when its a high amp draw.
    if you don't know
    https://www.youtube.com/watch?v=5v0Sv1LVMo4
  5. Jun 11, 2019 at 5:17 PM
    #45
    riverrockar
    Indiana
    Bagelboy nailed it. Automotive wiring gets vibrated too much, it needs a much more solid connector. Household use only.
    I would use them in an emergency, but I would have to be desperate. Like, Red Dawn desperate. Ruskies are coming desperate.:D
  6. Jun 11, 2019 at 6:43 PM
    #46
    whitepony04
    whitepony04 [OP] The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    I got my liquid tape in the post today, I’ll slather it on tomorrow. Amazon prime is the shiznit.
