Cali raised wiring
Discussion in 'Lighting' started by Otis1382, Oct 26, 2016.
  1. Oct 26, 2016 at 2:05 PM
    Otis1382
    Otis1382 [OP] Well-Known Member
    warren
    Chelsea Al
    '16 DCOR 4x4 quicksand
    Ok. Got a 32" bar from them with a wiring harness. how do I feed the wiring harness into the truck?
  2. Oct 26, 2016 at 2:06 PM
    Otis1382
    warren
    Chelsea Al
    Ok to cut a hole into the rubber boot going into the cab?
  3. Oct 26, 2016 at 8:02 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What I try to do if it will not go through the rubber boot is to cut a slit from the hole opening, not a new hole. The slit will re-seal and you won't be able to tell the difference.
  4. Oct 26, 2016 at 8:07 PM
    Otis1382
    warren
    Chelsea Al
    Ugh. that sounds great but I'm impatient . Just cut a jole
  5. Oct 26, 2016 at 8:08 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I'm a perfectionist.
  6. Oct 30, 2016 at 11:01 AM
    Johnnyvtx
    Johnnyvtx Well-Known Member
    I used the hole that the hood lift cable goes through. it is the same boot that the main cable uses. just spray some wd40 in there
